Ir para o conteúdo principal
OnePlus 6T Speaker Replacement
O que você precisa
  1. OnePlus 6T Speaker Replacement, Back Cover: passo 1, imagem 1 %32
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
  2. OnePlus 6T Speaker Replacement: passo 2, imagem 1 %32
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
  3. OnePlus 6T Speaker Replacement: passo 3, imagem 1 %32
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
  4. OnePlus 6T Speaker Replacement: passo 4, imagem 1 %32 OnePlus 6T Speaker Replacement: passo 4, imagem 2 %32 OnePlus 6T Speaker Replacement: passo 4, imagem 3 %32
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
  5. OnePlus 6T Speaker Replacement, Speaker: passo 5, imagem 1 %32
    • Remove seven 3mm Phillips #00 screws from the speaker.
  6. OnePlus 6T Speaker Replacement: passo 6, imagem 1 %32
    • Use a spudger to lift and remove the speaker.
Conclusão
7 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 62
Duração total: 2,787
