Introdução
If the audio coming from your OnePlus 6T speakers sounds distorted and troubleshooting doesn’t work, you may need to replace your speakers.
O que você precisa
Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
Remove the back cover from the phone.
7 outras pessoas executaram este guia.
