Ir para o conteúdo principal
OnePlus 6T Rear Camera Replacement
O que você precisa
  1. OnePlus 6T Rear Camera Replacement, Back Cover: passo 1, imagem 1 %32
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
    Pergunte ao FixBot
  2. OnePlus 6T Rear Camera Replacement: passo 2, imagem 1 %32
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
    Pergunte ao FixBot
  3. OnePlus 6T Rear Camera Replacement: passo 3, imagem 1 %32
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
    Pergunte ao FixBot
  4. OnePlus 6T Rear Camera Replacement: passo 4, imagem 1 %32 OnePlus 6T Rear Camera Replacement: passo 4, imagem 2 %32 OnePlus 6T Rear Camera Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    Plastic Cards
    $2.99
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
    Pergunte ao FixBot
  5. OnePlus 6T Rear Camera Replacement, Front Camera: passo 5, imagem 1 %32 OnePlus 6T Rear Camera Replacement, Front Camera: passo 5, imagem 2 %32
    • Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
    • Use tweezers to remove the battery cover and place it to the side.
    Pergunte ao FixBot
  6. OnePlus 6T Rear Camera Replacement: passo 6, imagem 1 %32
    • Remove eight 3mm Phillips #00 screws that connect the midframe to the phone.
    Pergunte ao FixBot
  7. OnePlus 6T Rear Camera Replacement: passo 7, imagem 1 %32
    • Using a spudger, gently remove the midframe and place it to the side.
    Pergunte ao FixBot
  8. OnePlus 6T Rear Camera Replacement: passo 8, imagem 1 %32
    • Using a spudger, lift the light brown tab in the middle of phone to disconnect the front camera.
    • Remove the front camera from the phone.
    Pergunte ao FixBot
  9. OnePlus 6T Rear Camera Replacement, Motherboard: passo 9, imagem 1 %32 OnePlus 6T Rear Camera Replacement, Motherboard: passo 9, imagem 2 %32
    • Remove the single 3mm Phillips #00 screw to the right of the top rear camera.
    Pergunte ao FixBot
  10. OnePlus 6T Rear Camera Replacement: passo 10, imagem 1 %32
    • Using a spudger, disconnect the charging port flex connector, the main flex connector, and the screen flex connector at the bottom of the camera.
    Pergunte ao FixBot
  11. OnePlus 6T Rear Camera Replacement: passo 11, imagem 1 %32
    • Use a spudger to disconnect the signal cables on the right side of the motherboard.
    Pergunte ao FixBot
  12. OnePlus 6T Rear Camera Replacement: passo 12, imagem 1 %32 OnePlus 6T Rear Camera Replacement: passo 12, imagem 2 %32
    • Disconnect the slider from the top of the phone with a spudger.
    • The slider is extremely delicate, so it is important you do not attempt to remove it from the sides.
    • Gently pull the motherboard from the left side and remove it from the phone.
    Pergunte ao FixBot
  13. OnePlus 6T Rear Camera Replacement, Rear Camera: passo 13, imagem 1 %32 OnePlus 6T Rear Camera Replacement, Rear Camera: passo 13, imagem 2 %32
    • Using a spudger, disconnect the two metal rear camera tabs on the left side of the camera.
    • Remove the camera from its slot on the motherboard.
    Pergunte ao FixBot
Conclusão
3 outras pessoas executaram este guia.
1Comentário do guia
In step 6 the screw under the humidity sensor is not shown. this needs to be removed as well
W W - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 90
Ao todo: 1,763
