Introdução
Use this guide to replace a broken or cracked OnePlus 6T Front Camera.
O que você precisa
Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
Ferramenta utilizada neste passo:Plastic Cards$2.99
Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
Remove the back cover from the phone.
Ferramenta utilizada neste passo:Tweezers$4.99
Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
Use tweezers to remove the battery cover and place it to the side.
