Ir para o conteúdo principal
OnePlus 5 Vibration Motor Replacement
O que você precisa
  1. OnePlus 5 Vibration Motor Replacement, SIM Card Tray: passo 1, imagem 1 %32 OnePlus 5 Vibration Motor Replacement, SIM Card Tray: passo 1, imagem 2 %32 OnePlus 5 Vibration Motor Replacement, SIM Card Tray: passo 1, imagem 3 %32
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole below the SIM card tray, located near the rear cameras on the edge of the phone.
    • Press firmly to eject the tray.
    • During reassembly, be sure to properly orient the SIM tray you you insert it.
  2. OnePlus 5 Vibration Motor Replacement, Back Cover: passo 2, imagem 1 %32
    • Remove the two 2.6 mm T2 screws straddling the USB-C port on the bottom edge of the phone.
  3. OnePlus 5 Vibration Motor Replacement: passo 3, imagem 1 %32 OnePlus 5 Vibration Motor Replacement: passo 3, imagem 2 %32 OnePlus 5 Vibration Motor Replacement: passo 3, imagem 3 %32
    • There is a high risk of damaging the display panel if this opening procedure is improperly followed.
    • The following four steps show how to pry the rear case from the plastic frame. Read through the steps first before attempting the procedure.
    • There are two different seams between the body and the screen of the phone:
    • Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
    • Frame seam: This is where the plastic frame meets the back cover. Only pry at this seam.
    • There are twelve clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
  4. OnePlus 5 Vibration Motor Replacement: passo 4, imagem 1 %32 OnePlus 5 Vibration Motor Replacement: passo 4, imagem 2 %32
    • As you work, try not to accidentally power on the phone. If you do, turn the phone off before resuming disassembly.
    • Place a suction cup near the bottom edge of the display.
    • Pull on the suction cup with strong steady force.
    • Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
    • Due to tight tolerances, this will take substantial force. Using a new opening tool with an unmarred edge will help with this step.
  5. OnePlus 5 Vibration Motor Replacement: passo 5, imagem 1 %32 OnePlus 5 Vibration Motor Replacement: passo 5, imagem 2 %32 OnePlus 5 Vibration Motor Replacement: passo 5, imagem 3 %32
    • Once the opening tool's edge is wedged in position, carefully slide the tool along the bottom edge of the phone.
    • Carefully guide the opening tool around the left corner of the phone while keeping the tool's edge within the seam.
  6. OnePlus 5 Vibration Motor Replacement: passo 6, imagem 1 %32 OnePlus 5 Vibration Motor Replacement: passo 6, imagem 2 %32
    • Lever the opening tool to release the first clip from the frame.
  7. OnePlus 5 Vibration Motor Replacement: passo 7, imagem 1 %32 OnePlus 5 Vibration Motor Replacement: passo 7, imagem 2 %32 OnePlus 5 Vibration Motor Replacement: passo 7, imagem 3 %32
    • Continue sliding the opening tool along the long edge, releasing the clips along the way.
    • The last clip in the top-left corner near the front-facing camera is recessed and can be difficult to release. Take your time and use the flat end of a spudger or an opening pick to help.
  8. OnePlus 5 Vibration Motor Replacement: passo 8, imagem 1 %32
    • With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
    • The frame is still connected to the back cover by a long flex cable. Do not remove the back cover.
    • During reassembly, pause here to test your phone's functionality before securing the back cover.
    • To reinstall the back cover:
    • Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
    • Squeeze along the long edges of the phone to snap the remaining clips into place.
  9. OnePlus 5 Vibration Motor Replacement: passo 9, imagem 1 %32 OnePlus 5 Vibration Motor Replacement: passo 9, imagem 2 %32 OnePlus 5 Vibration Motor Replacement: passo 9, imagem 3 %32
    • With all the clips released, flip the phone over so that the display is face-down.
    • Swing the back cover around and rest it on top of the exposed frame.
    • Be careful not to stress the flex cable connecting the back cover and the frame.
  10. OnePlus 5 Vibration Motor Replacement: passo 10, imagem 1 %32 OnePlus 5 Vibration Motor Replacement: passo 10, imagem 2 %32
    • Remove the 2.6 mm Phillips screw holding the cable bracket above the battery in place.
    • Lift up and remove the cable bracket.
    • To reinstall the bracket, position one end into place, and bend the bracket slightly to spring the other end into place.
  11. OnePlus 5 Vibration Motor Replacement: passo 11, imagem 1 %32 OnePlus 5 Vibration Motor Replacement: passo 11, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the back cover flex cable from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  12. OnePlus 5 Vibration Motor Replacement: passo 12, imagem 1 %32
    • Remove the back cover.
  13. OnePlus 5 Vibration Motor Replacement, OnePlus 5 Battery Disconnect: passo 13, imagem 1 %32 OnePlus 5 Vibration Motor Replacement, OnePlus 5 Battery Disconnect: passo 13, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the battery connector from its socket.
  14. OnePlus 5 Vibration Motor Replacement, Loudspeaker: passo 14, imagem 1 %32
    • Remove the six 2.6 mm Phillips screws securing the loudspeaker to the frame.
  15. OnePlus 5 Vibration Motor Replacement: passo 15, imagem 1 %32 OnePlus 5 Vibration Motor Replacement: passo 15, imagem 2 %32
    • Insert the flat end of a spudger into the corner of the loudspeaker assembly and pry slightly, loosening the loudspeaker from its recess.
  16. OnePlus 5 Vibration Motor Replacement: passo 16, imagem 1 %32
    • Remove the loudspeaker.
    • To reinstall the loudspeaker, align the loudspeaker's bottom edge to the frame, then press the assembly into place.
    • During reinstallation, make sure that the display cable connector under the loudspeaker assembly is still securely fastened.
  17. OnePlus 5 Vibration Motor Replacement, OnePlus 5 Interconnect Cable Disconnect: passo 17, imagem 1 %32 OnePlus 5 Vibration Motor Replacement, OnePlus 5 Interconnect Cable Disconnect: passo 17, imagem 2 %32 OnePlus 5 Vibration Motor Replacement, OnePlus 5 Interconnect Cable Disconnect: passo 17, imagem 3 %32
    • Use the point of a spudger to pry up and disconnect the interconnect flex cable from the socket.
    • If you are replacing the battery, bend the interconnect flex cable away from the phone and secure it out of the way with a rubber band or tape.
  18. OnePlus 5 Vibration Motor Replacement, Motherboard: passo 18, imagem 1 %32 OnePlus 5 Vibration Motor Replacement, Motherboard: passo 18, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the display interconnect cable from its socket near the bottom edge of the motherboard.
  19. OnePlus 5 Vibration Motor Replacement: passo 19, imagem 1 %32 OnePlus 5 Vibration Motor Replacement: passo 19, imagem 2 %32
    • Slide the point of a spudger underneath the antenna interconnect cable that is connected to the motherboard above the vibration motor.
    • Pry up to disconnect the cable from its socket.
    • De-route the cable out of its motherboard grounding clip and move it out of the way.
  20. OnePlus 5 Vibration Motor Replacement: passo 20, imagem 1 %32 OnePlus 5 Vibration Motor Replacement: passo 20, imagem 2 %32
    • Slide the point of a spudger under the small square antenna connector connected to the motherboard near the top edge.
    • Pry up to disconnect the antenna connector from its socket.
  21. OnePlus 5 Vibration Motor Replacement: passo 21, imagem 1 %32
    • Remove the following seven 2.6 mm Phillips screws securing the motherboard:
    • Some screws may be hidden under stickers. Remove the stickers to access the screws.
  22. OnePlus 5 Vibration Motor Replacement: passo 22, imagem 1 %32 OnePlus 5 Vibration Motor Replacement: passo 22, imagem 2 %32 OnePlus 5 Vibration Motor Replacement: passo 22, imagem 3 %32
    • Use your fingers to lift up the top edge of the motherboard.
    • Lift the motherboard out of its recess and remove it.
  23. OnePlus 5 Vibration Motor Replacement, Vibration Motor: passo 23, imagem 1 %32 OnePlus 5 Vibration Motor Replacement, Vibration Motor: passo 23, imagem 2 %32 OnePlus 5 Vibration Motor Replacement, Vibration Motor: passo 23, imagem 3 %32
    • Wedge the point of an opening pick between the vibration motor and the frame and push downward to loosen the vibration motor from its recess.
    • Once the vibration motor is slightly loosened, you can wedge the flat end of a spudger between the motor and the frame to help free it from its recess.
  24. OnePlus 5 Vibration Motor Replacement: passo 24, imagem 1 %32 OnePlus 5 Vibration Motor Replacement: passo 24, imagem 2 %32
    • Slide the point of an opening pick underneath the vibration motor's flex pad and gently pry it off of the frame.
    • Remove the vibration motor.
Conclusão
Repair didn’t go as planned? Check out our OnePlus 5 Answers Community for troubleshooting help.
Arthur Shi
Membro desde: 01/03/18
258.910 Reputação
Autoria de 531 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.074 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 1,227
