Introdução
The OnePlus 5 has a small daughterboard that mainly houses contact points that connect to loudspeaker and charging assemblies. If you are experiencing issues with any of the functions housed in the bottom half of your phone (e.g., microphone, loudspeaker, charging port) follow this guide to replace the daughterboard in your OnePlus 5. The hardest part of this guide is getting the frame clips of the back cover free to access the internals.
Some guide images will show the battery already removed from the phone. You do not need to remove the battery for the daughterboard procedure.
O que você precisa
Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole below the SIM card tray, located near the rear cameras on the edge of the phone.
Press firmly to eject the tray.
Remove the two 2.6 mm T2 screws straddling the USB-C port on the bottom edge of the phone.
Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
Frame seam: This is where the plastic frame meets the back cover. Only pry at this seam.
There are twelve clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
Squeeze along the long edges of the phone to snap the remaining clips into place.
Use the point of a spudger to pry up and disconnect the battery connector from its socket.
Remove the six 2.6 mm Phillips screws securing the loudspeaker to the frame.
Use the point of a spudger to pry up and disconnect the interconnect flex cable from the socket.
Use the point of a spudger the pry up and disconnect the fingerprint scanner connector from its socket on the daughterboard.
Repair didn’t go as planned? Check out our OnePlus 5 Answers Community for troubleshooting help.
Uma outra pessoa concluiu este guia.
2Comentários do guia
Hi ! My microphone was damaged so I bought a replacement daughterboard but neither the microphone nor the speakers worked after installing it :(
I reinstalled the old one with the damaged microphone and the speakers worked fine. Any idea what could cause the issue ?
