Ir para o conteúdo principal
OneLink Safe and Sound Microphone Replacement
O que você precisa
  1. OneLink Safe and Sound Microphone Replacement, Cover: passo 1, imagem 1 %32 OneLink Safe and Sound Microphone Replacement, Cover: passo 1, imagem 2 %32
    • Run the metal spudger under the plastic rim and around the perimeter, on the top of the device to loosen the adhesive.
    • Remove plastic rim.
  2. OneLink Safe and Sound Microphone Replacement: passo 2, imagem 1 %32 OneLink Safe and Sound Microphone Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove nine screws from the top of the device.
  3. OneLink Safe and Sound Microphone Replacement: passo 3, imagem 1 %32 OneLink Safe and Sound Microphone Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Don't yank or pull the lid off as there are ribbons and cables connecting the top of the device to the motherboard. They need to be disconnected before the top is removed.
    • Use tweezers or a spudger to disconnect the ribbon from the motherboard.
  4. OneLink Safe and Sound Microphone Replacement: passo 4, imagem 1 %32
    • Use tweezers to unplug the speaker cable from the motherboard.
  5. OneLink Safe and Sound Microphone Replacement: passo 5, imagem 1 %32 OneLink Safe and Sound Microphone Replacement: passo 5, imagem 2 %32
    • Use the plastic opening tool to remove the microphone connection from the motherboard.
    • Remove the top of the device.
  6. OneLink Safe and Sound Microphone Replacement, Microphone: passo 6, imagem 1 %32 OneLink Safe and Sound Microphone Replacement, Microphone: passo 6, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the two screws that secure the microphone to the device.
  7. OneLink Safe and Sound Microphone Replacement: passo 7, imagem 1 %32
    • Use your hands to remove the microphone.
Conclusão
Arianna Roberts
Membro desde: 11/10/22
657 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 2-2, Petersen Fall 2022 Membro de UMass Dartmouth, Team 2-2, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G2
3 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 217
