Ir para o conteúdo principal
Onda V701 Front- Facing Camera Replacement
O que você precisa
    1. Onda V701 Front- Facing Camera Replacement, Back Panel: passo 1, imagem 1 %32 Onda V701 Front- Facing Camera Replacement, Back Panel: passo 1, imagem 2 %32 Onda V701 Front- Facing Camera Replacement, Back Panel: passo 1, imagem 3 %32
      • Ensure device is powered off before disassembly.
      • Remove the 4 rubber screw plugs using a spudger.
      Pergunte ao FixBot
      Comentar
    2. Onda V701 Front- Facing Camera Replacement: passo 2, imagem 1 %32 Onda V701 Front- Facing Camera Replacement: passo 2, imagem 2 %32 Onda V701 Front- Facing Camera Replacement: passo 2, imagem 3 %32
      • Remove the four 4.8mm mounting screws using a PH00 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Onda V701 Front- Facing Camera Replacement: passo 3, imagem 1 %32 Onda V701 Front- Facing Camera Replacement: passo 3, imagem 2 %32
      • Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
      • Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
      Pergunte ao FixBot
      Comentar
    4. Onda V701 Front- Facing Camera Replacement: passo 4, imagem 1 %32 Onda V701 Front- Facing Camera Replacement: passo 4, imagem 2 %32
      • Gently lift the screen assembly away from the back cover assembly.
      • Be careful when separating the two pieces as the screen assembly is still connected to the mother board by two ribbon cables.
      Pergunte ao FixBot
      Comentar
    5. Onda V701 Front- Facing Camera Replacement: passo 5, imagem 1 %32 Onda V701 Front- Facing Camera Replacement: passo 5, imagem 2 %32 Onda V701 Front- Facing Camera Replacement: passo 5, imagem 3 %32
      • Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
      • Remove the ribbon cables.
      Pergunte ao FixBot
      Comentar
    1. Onda V701 Front- Facing Camera Replacement, Front- Facing Camera: passo 6, imagem 1 %32 Onda V701 Front- Facing Camera Replacement, Front- Facing Camera: passo 6, imagem 2 %32
      • Gently pry the front-facing camera away from the back panel using a spudger.
      Pergunte ao FixBot
      Comentar
    2. Onda V701 Front- Facing Camera Replacement: passo 7, imagem 1 %32 Onda V701 Front- Facing Camera Replacement: passo 7, imagem 2 %32
      • Flip the gray locking tab of the ribbon connector up using a spudger.
      • Remove the ribbon cable from the connector.
      Pergunte ao FixBot
      Comentar
    3. Onda V701 Front- Facing Camera Replacement: passo 8, imagem 1 %32
      • Remove the front-facing camera assembly.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 23
Ao todo: 514
