Ir para o conteúdo principal
Onda V701 Battery Replacement
O que você precisa
    1. Onda V701 Battery Replacement, Back Panel: passo 1, imagem 1 %32 Onda V701 Battery Replacement, Back Panel: passo 1, imagem 2 %32 Onda V701 Battery Replacement, Back Panel: passo 1, imagem 3 %32
      • Ensure device is powered off before disassembly.
      • Remove the 4 rubber screw plugs using a spudger.
      Pergunte ao FixBot
      Comentar
    2. Onda V701 Battery Replacement: passo 2, imagem 1 %32 Onda V701 Battery Replacement: passo 2, imagem 2 %32 Onda V701 Battery Replacement: passo 2, imagem 3 %32
      • Remove the four 4.8mm mounting screws using a PH00 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Onda V701 Battery Replacement: passo 3, imagem 1 %32 Onda V701 Battery Replacement: passo 3, imagem 2 %32
      • Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
      • Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
      Pergunte ao FixBot
      Comentar
    4. Onda V701 Battery Replacement: passo 4, imagem 1 %32 Onda V701 Battery Replacement: passo 4, imagem 2 %32
      • Gently lift the screen assembly away from the back cover assembly.
      • Be careful when separating the two pieces as the screen assembly is still connected to the mother board by two ribbon cables.
      Pergunte ao FixBot
      Comentar
    5. Onda V701 Battery Replacement: passo 5, imagem 1 %32 Onda V701 Battery Replacement: passo 5, imagem 2 %32 Onda V701 Battery Replacement: passo 5, imagem 3 %32
      • Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
      • Remove the ribbon cables.
      Pergunte ao FixBot
      Comentar
    1. Onda V701 Battery Replacement, Battery: passo 6, imagem 1 %32
      Ferramenta utilizada neste passo:
      • Desolder the red(+) and black(-) wires connecting the battery to the motherboard using a soldering iron and tweezers to hold the wire.
      • Soldering requires a lot of heat. Do not touch the metal part of the soldering iron. Wear gloves if necessary to protect your hands. The fumes from soldering could also be toxic. Work in a well ventilated area and/or use a respirator.
      Pergunte ao FixBot
      Comentar
    2. Onda V701 Battery Replacement: passo 7, imagem 1 %32 Onda V701 Battery Replacement: passo 7, imagem 2 %32 Onda V701 Battery Replacement: passo 7, imagem 3 %32
      • Carefully pry the battery away from the back panel using the nylon or metal spudger.
      • Gently remove the battery from the back panel.
      • Ensure not to excessively bend or puncture the battery. Doing so could cause the battery to catch on fire or explode.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 25
Ao todo: 1,261
