Ir para o conteúdo principal
Omaker M4 Motherboard Replacement
O que você precisa
  1. Omaker M4 Motherboard Replacement, Back Case: passo 1, imagem 1 %32
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
    Pergunte ao FixBot
    Comentar
  2. Omaker M4 Motherboard Replacement: passo 2, imagem 1 %32 Omaker M4 Motherboard Replacement: passo 2, imagem 2 %32
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
    Pergunte ao FixBot
    Comentar
  3. Omaker M4 Motherboard Replacement: passo 3, imagem 1 %32 Omaker M4 Motherboard Replacement: passo 3, imagem 2 %32
    • Use a magnet to remove the screws after unscrewing them and place them aside.
    Pergunte ao FixBot
    Comentar
  4. Omaker M4 Motherboard Replacement: passo 4, imagem 1 %32
    • Carefully remove the back cover without breaking the battery wire.
    Pergunte ao FixBot
    Comentar
  5. Omaker M4 Motherboard Replacement: passo 5, imagem 1 %32 Omaker M4 Motherboard Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
    Pergunte ao FixBot
    Comentar
  6. Omaker M4 Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 Omaker M4 Motherboard Replacement, Motherboard: passo 6, imagem 2 %32
    • Remove the mic wire by carefully pulling the plug out of the socket.
    Pergunte ao FixBot
    Comentar
  7. Omaker M4 Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the speaker wire by carefully pulling the plug out of the socket on the motherboard.
    Pergunte ao FixBot
    Comentar
  8. Omaker M4 Motherboard Replacement: passo 8, imagem 1 %32 Omaker M4 Motherboard Replacement: passo 8, imagem 2 %32
    • Use Phillips PH00 screwdriver to remove the three screws holding the motherboard in place.
    Pergunte ao FixBot
    Comentar
  9. Omaker M4 Motherboard Replacement: passo 9, imagem 1 %32 Omaker M4 Motherboard Replacement: passo 9, imagem 2 %32
    • Remove the screws using the screwdriver.
    • Since the screws that hold the motherboard in place are smaller, the screwdriver is able to pick them up.
    Pergunte ao FixBot
    Comentar
  10. Omaker M4 Motherboard Replacement: passo 10, imagem 1 %32 Omaker M4 Motherboard Replacement: passo 10, imagem 2 %32
    • Carefully remove the motherboard with your hand by lifting it from the device.
    Pergunte ao FixBot
    Comentar
Conclusão
[deleted]
Membro desde: 02/17/16
679 Reputação
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 43
Ao todo: 1,643
