Ir para o conteúdo principal
Olympus SZ-12 Lens Replacement
O que você precisa
    1. Olympus SZ-12 Lens Replacement, Back Case: passo 1, imagem 1 %32 Olympus SZ-12 Lens Replacement, Back Case: passo 1, imagem 2 %32
      • Remove nine 4.45mm Phillips #000 screws from the outside of the case.
      Pergunte ao FixBot
      Comentar
    2. Olympus SZ-12 Lens Replacement: passo 2, imagem 1 %32
      • There are four screws to take out on the bottom of the camera.
      Pergunte ao FixBot
      Comentar
    3. Olympus SZ-12 Lens Replacement: passo 3, imagem 1 %32
      • There are three screws to take out on this side.
      Pergunte ao FixBot
      Comentar
    4. Olympus SZ-12 Lens Replacement: passo 4, imagem 1 %32
      • There is one screw to take out on this side.
      Pergunte ao FixBot
      Comentar
    5. Olympus SZ-12 Lens Replacement: passo 5, imagem 1 %32
      • There is one hidden screw inside the HDMI port.
      Pergunte ao FixBot
      Comentar
    6. Olympus SZ-12 Lens Replacement: passo 6, imagem 1 %32
      • Using the blue plastic opening tool, wedge open and remove the case.
      Pergunte ao FixBot
      Comentar
    1. Olympus SZ-12 Lens Replacement, LCD Screen: passo 7, imagem 1 %32
      • Once you have the back case off, remove the LCD Screen.
      Pergunte ao FixBot
      Comentar
    2. Olympus SZ-12 Lens Replacement: passo 8, imagem 1 %32
      • Using a plastic opening tool, gently lift the retaining flap on the display cable ZIF connector.
      • Pull the display cable from its socket on the motherboard.
      Pergunte ao FixBot
      Comentar
    3. Olympus SZ-12 Lens Replacement: passo 9, imagem 1 %32
      • Remove the LCD screen from the device.
      • Be careful not to rip the display's ribbon cable as you pull the screen away from the device.
      Pergunte ao FixBot
      Comentar
    1. Olympus SZ-12 Lens Replacement, Lens: passo 10, imagem 1 %32 Olympus SZ-12 Lens Replacement, Lens: passo 10, imagem 2 %32
      • Remove the four 3.8mm Phillips #000 screws from the LCD frame.
      Pergunte ao FixBot
      Comentar
    2. Olympus SZ-12 Lens Replacement: passo 11, imagem 1 %32 Olympus SZ-12 Lens Replacement: passo 11, imagem 2 %32 Olympus SZ-12 Lens Replacement: passo 11, imagem 3 %32
      • Remove the top left screw, top right screw, bottom left screw, and bottom right screw from LCD frame.
      Pergunte ao FixBot
      Comentar
    3. Olympus SZ-12 Lens Replacement: passo 12, imagem 1 %32 Olympus SZ-12 Lens Replacement: passo 12, imagem 2 %32 Olympus SZ-12 Lens Replacement: passo 12, imagem 3 %32
      • Lift the retaining flaps on the three remaining ZIF connectors connected to the motherboard.
      Pergunte ao FixBot
      Comentar
    4. Olympus SZ-12 Lens Replacement: passo 13, imagem 1 %32
      • Remove the five 4.3mm Phillips #000 screws from the lens frame to access the lens.
      • Remove the lens frame.
      Pergunte ao FixBot
      Comentar
    5. Olympus SZ-12 Lens Replacement: passo 14, imagem 1 %32 Olympus SZ-12 Lens Replacement: passo 14, imagem 2 %32 Olympus SZ-12 Lens Replacement: passo 14, imagem 3 %32
      • Remove two 4.3mm Phillips #000 screws from black plastic piece surrounding the lens.
      • Remove the lens.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
1Comentário do guia
Is her anything in the lens assembly that I could look for which may have dislodged showing up as a shadow on the bottom of the display screen
Deacon - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 16
Últimos 30 dias: 51
Ao todo: 2,543
