Ir para o conteúdo principal
Olympus FE-170 Flash Assembly Replacement
O que você precisa
  1. Olympus FE-170 Flash Assembly Replacement, Casing: passo 1, imagem 1 %32 Olympus FE-170 Flash Assembly Replacement, Casing: passo 1, imagem 2 %32
    • Remove the 2 exposed screws on opposite sides of the camera. Turn the screws counter-clockwise to remove.
    Pergunte ao FixBot
    Comentar
  2. Olympus FE-170 Flash Assembly Replacement: passo 2, imagem 1 %32 Olympus FE-170 Flash Assembly Replacement: passo 2, imagem 2 %32
    • Open the battery compartment and remove the 2 screws in the top of the opening.
    Pergunte ao FixBot
    Comentar
  3. Olympus FE-170 Flash Assembly Replacement: passo 3, imagem 1 %32 Olympus FE-170 Flash Assembly Replacement: passo 3, imagem 2 %32
    • Remove the 2 exposed screws on the bottom of the camera.
    Pergunte ao FixBot
    Comentar
  4. Olympus FE-170 Flash Assembly Replacement: passo 4, imagem 1 %32
    • Uncover the mini-usb dock on the side of the camera and unscrew the screw next to the flap joint
    Pergunte ao FixBot
    Comentar
  5. Olympus FE-170 Flash Assembly Replacement: passo 5, imagem 1 %32
    • Uncover the video cable port on the side of the camera and remove the screw
    Pergunte ao FixBot
    Comentar
  6. Olympus FE-170 Flash Assembly Replacement: passo 6, imagem 1 %32 Olympus FE-170 Flash Assembly Replacement: passo 6, imagem 2 %32
    • Carefully slip the head of the plastic opening tool under the panels by finding the crack between the panels. Lightly apply pressure in the shown places at the top and bottom of the camera.
    Pergunte ao FixBot
    Comentar
  7. Olympus FE-170 Flash Assembly Replacement: passo 7, imagem 1 %32 Olympus FE-170 Flash Assembly Replacement: passo 7, imagem 2 %32
    • Loosen the panels on the sides of the camera in the shown places by slipping the plastic opening tool in the crack between the panels. Lightly apply pressure.
    Pergunte ao FixBot
    Comentar
  8. Olympus FE-170 Flash Assembly Replacement: passo 8, imagem 1 %32 Olympus FE-170 Flash Assembly Replacement: passo 8, imagem 2 %32
    • Ensure that the panels have been loosened. Carefully use hands to pull back and remove the panels.
    Pergunte ao FixBot
    Comentar
  9. Olympus FE-170 Flash Assembly Replacement, Flash Assembly: passo 9, imagem 1 %32 Olympus FE-170 Flash Assembly Replacement, Flash Assembly: passo 9, imagem 2 %32 Olympus FE-170 Flash Assembly Replacement, Flash Assembly: passo 9, imagem 3 %32
    • Remove the two small screws on the top of the flash itself.
    Pergunte ao FixBot
    Comentar
  10. Olympus FE-170 Flash Assembly Replacement: passo 10, imagem 1 %32 Olympus FE-170 Flash Assembly Replacement: passo 10, imagem 2 %32
    • Use the spudger to gently pry the top of the thin metal casing around the flash loose.
    Pergunte ao FixBot
    Comentar
  11. Olympus FE-170 Flash Assembly Replacement: passo 11, imagem 1 %32
    • Use the spudger to gently pry the bottom of the thin metal casing around the flash loose.
    Pergunte ao FixBot
    Comentar
  12. Olympus FE-170 Flash Assembly Replacement: passo 12, imagem 1 %32 Olympus FE-170 Flash Assembly Replacement: passo 12, imagem 2 %32
    • Use your fingers to gently pull the metal casing off of the flash.
    • Remove the plastic flash diffuser by gently prying at the edges with your fingers.
    Pergunte ao FixBot
    Comentar
  13. Olympus FE-170 Flash Assembly Replacement: passo 13, imagem 1 %32 Olympus FE-170 Flash Assembly Replacement: passo 13, imagem 2 %32
    • Remove the screw holding the flash circuit board in place.
    Pergunte ao FixBot
    Comentar
  14. Olympus FE-170 Flash Assembly Replacement: passo 14, imagem 1 %32
    • Pull the flash-bulb sub-assembly out of its place by using the pointed end of the spudger.
    Pergunte ao FixBot
    Comentar
  15. Olympus FE-170 Flash Assembly Replacement: passo 15, imagem 1 %32 Olympus FE-170 Flash Assembly Replacement: passo 15, imagem 2 %32 Olympus FE-170 Flash Assembly Replacement: passo 15, imagem 3 %32
    • Use the pointed end of the spudger to pull up both layers of tape on top of the flash-bulb sub-assembly.
    • Remove the wire layered in between the two sections of tape from the flash-bulb sub-assembly.
    Pergunte ao FixBot
    Comentar
  16. Olympus FE-170 Flash Assembly Replacement: passo 16, imagem 1 %32
    • Pull the flash circuit board and flash-bulb sub-assembly off from the front of the camera.
    Pergunte ao FixBot
    Comentar
  17. Olympus FE-170 Flash Assembly Replacement: passo 17, imagem 1 %32 Olympus FE-170 Flash Assembly Replacement: passo 17, imagem 2 %32 Olympus FE-170 Flash Assembly Replacement: passo 17, imagem 3 %32
    • Use the spudger to push the black capacitor out from its slot.
    • Remove the entire flash assembly by gently pulling outward and away from the camera.
    Pergunte ao FixBot
    Comentar
Conclusão
Tyler Hartwig
Membro desde: 03/24/15
337 Reputação
Autoria de 3 guias
Equipe
Baylor, Team 6-4, Shaver Spring 2015 Membro de Baylor, Team 6-4, Shaver Spring 2015
BU-SHAVER-S15S6G4
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 32
Ao todo: 718
