Ir para o conteúdo principal
Olympus Digital Camera TG-3 Shutter Button Replacement
O que você precisa
    1. Olympus Digital Camera TG-3 Shutter Button  Replacement, Front Case: passo 1, imagem 1 %32
      • Locate the strap eyelet side of the camera and use the PH000 screwdriver to remove the two 5.3mm screws that hold the strap.
      Pergunte ao FixBot
      Comentar
    2. Olympus Digital Camera TG-3 Shutter Button  Replacement: passo 2, imagem 1 %32
      • Locate the side of the camera containing the HDMI port. Use the PH000 screwdriver to remove the 5.4mm screw located on the lower left side below the port.
      Pergunte ao FixBot
      Comentar
    3. Olympus Digital Camera TG-3 Shutter Button  Replacement: passo 3, imagem 1 %32
      • Using the PH000 screwdriver, remove the 3.8mm screw located inside the HDMI port.
      Pergunte ao FixBot
      Comentar
    4. Olympus Digital Camera TG-3 Shutter Button  Replacement: passo 4, imagem 1 %32
      • Locate the bottom section of the camera. Using the PH000 screwdriver, remove the two 4mm screws located towards the middle (near the battery compartment).
      Pergunte ao FixBot
      Comentar
    5. Olympus Digital Camera TG-3 Shutter Button  Replacement: passo 5, imagem 1 %32
      • Now you should be able to remove the front case easily using your hand.
      Pergunte ao FixBot
      Comentar
    1. Olympus Digital Camera TG-3 Shutter Button  Replacement, Back Case: passo 6, imagem 1 %32
      • Using the PH000 screwdriver, remove the two 4mm screws located on the left side of the camera, under the strap holder.
      Pergunte ao FixBot
      Comentar
    2. Olympus Digital Camera TG-3 Shutter Button  Replacement: passo 7, imagem 1 %32
      • Use a PH000 screwdriver to remove the 3 mm screw located on the bottom of the battery compartment.
      Pergunte ao FixBot
      Comentar
    3. Olympus Digital Camera TG-3 Shutter Button  Replacement: passo 8, imagem 1 %32
      • Hold the device as shown in the picture. Using the PH000 screwdriver, remove the 9mm screw located on the upper left side of the camera.
      Pergunte ao FixBot
      Comentar
    4. Olympus Digital Camera TG-3 Shutter Button  Replacement: passo 9, imagem 1 %32
      • Use the PH000 screwdriver to remove the 7mm screw you'll find toward the lower left side of the camera.
      Pergunte ao FixBot
      Comentar
    5. Olympus Digital Camera TG-3 Shutter Button  Replacement: passo 10, imagem 1 %32
      • Use a PH000 screwdriver to remove the 6mm screw on the upper right side of the camera, above the flash.
      Pergunte ao FixBot
      Comentar
    6. Olympus Digital Camera TG-3 Shutter Button  Replacement: passo 11, imagem 1 %32
      • Using the PH000 screwdriver, remove the 1.2 mm located on the lower right side of the device, towards the corner.
      Pergunte ao FixBot
      Comentar
    7. Olympus Digital Camera TG-3 Shutter Button  Replacement: passo 12, imagem 1 %32
      • Use the PH0000 screwdriver to remove the 7 mm located on the upper side of the camera, where the shutter and zoom bottoms are. You will find the screw towards the middle of this section.
      Pergunte ao FixBot
      Comentar
    8. Olympus Digital Camera TG-3 Shutter Button  Replacement: passo 13, imagem 1 %32
      • Remove the back case using your hand.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Natalia Morales
Membro desde: 10/11/16
675 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-6, Leahy Fall 2016 Membro de USF Tampa, Team 1-6, Leahy Fall 2016
USFT-LEAHY-F16S1G6
3 Membros
Autoria de 10 guias
2Comentários do guia
Bravo super tutorial, but how to ensure the sealing after disassembly and reassembly?
vincent vidal - Responder Compartilhar
I have a problem recovering the original condition. Is it possible Someone help me to restore it. Olympus TG-3 contact back. Witrocker@hotmail.com
Dawis rocker - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 62
Ao todo: 4,392
