Ir para o conteúdo principal
Olympus D590 Lens Replacement
O que você precisa
  1. Olympus D590 Lens Replacement, Face Plate: passo 1, imagem 1 %32
    • Remove five baseplate screws using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Olympus D590 Lens Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
    Pergunte ao FixBot
    Comentar
  3. Olympus D590 Lens Replacement: passo 3, imagem 1 %32
    • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Olympus D590 Lens Replacement: passo 4, imagem 1 %32
    • Using tweezers, lift the rubber plate to expose the ports.
    Pergunte ao FixBot
    Comentar
  5. Olympus D590 Lens Replacement: passo 5, imagem 1 %32
    • Remove two screws from the ports using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  6. Olympus D590 Lens Replacement: passo 6, imagem 1 %32
    • Use a spudger to pry the faceplate away from the rest of the camera.
    Pergunte ao FixBot
    Comentar
  7. Olympus D590 Lens Replacement: passo 7, imagem 1 %32
    • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
    • Damage to the connector line will prevent the on/off power switch's operational function.
    Pergunte ao FixBot
    Comentar
  8. Olympus D590 Lens Replacement, Backplate: passo 8, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove three screws fastened to the camera backplate edge.
    Pergunte ao FixBot
    Comentar
  9. Olympus D590 Lens Replacement: passo 9, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the two camera flash screws secured to either side of bulb housing component.
    Pergunte ao FixBot
    Comentar
  10. Olympus D590 Lens Replacement: passo 10, imagem 1 %32
    • Using an iFixit opening tool, pry the backplate from the camera internal housing component.
    Pergunte ao FixBot
    Comentar
  11. Olympus D590 Lens Replacement: passo 11, imagem 1 %32
    • Pull the backplate away from the camera internal housing component.
    Pergunte ao FixBot
    Comentar
  12. Olympus D590 Lens Replacement, LCD Screen: passo 12, imagem 1 %32
    • Remove one screw Phillips #00 from the right side of the LCD screen camera internal housing component.
    Pergunte ao FixBot
    Comentar
  13. Olympus D590 Lens Replacement: passo 13, imagem 1 %32 Olympus D590 Lens Replacement: passo 13, imagem 2 %32
    • To check that all screws are removed from the exterior side panel, gradually slide and lift no more than 3cm away from the camera internal component body.
    Pergunte ao FixBot
    Comentar
  14. Olympus D590 Lens Replacement: passo 14, imagem 1 %32 Olympus D590 Lens Replacement: passo 14, imagem 2 %32
    • View the front of the camera internal housing component.
    • Using tweezers, detach the gray connector and blue wiring tape.
    • Be cautious to gently wiggle and pull blue wiring tape and gray wire connector during detachment.
    Pergunte ao FixBot
    Comentar
  15. Olympus D590 Lens Replacement: passo 15, imagem 1 %32 Olympus D590 Lens Replacement: passo 15, imagem 2 %32
    • View the top of the camera internal housing component.
    • Using tweezers, gently lift the black tape exposing all connector wires.
    Pergunte ao FixBot
    Comentar
  16. Olympus D590 Lens Replacement: passo 16, imagem 1 %32
    • View the bottom of the camera internal housing component.
    • Caution: Keep yellow taped wire attached to the LCD screen.
    • Use tweezers to gently wiggle, pull, and detach tape from the surface of the camera internal housing component.
    Pergunte ao FixBot
    Comentar
  17. Olympus D590 Lens Replacement: passo 17, imagem 1 %32 Olympus D590 Lens Replacement: passo 17, imagem 2 %32 Olympus D590 Lens Replacement: passo 17, imagem 3 %32
    • Using tweezers, gently lift the speaker, cautiously maneuvering the wire away from the side of the internal housing component toward the front of the camera internal housing component.
    Pergunte ao FixBot
    Comentar
  18. Olympus D590 Lens Replacement: passo 18, imagem 1 %32 Olympus D590 Lens Replacement: passo 18, imagem 2 %32
    • Gently lift the LCD screen away from the camera internal housing component hinging the thick yellow wiring tape attached to the camera internal housing component.
    • Use a forefinger and thumb to gently pull the thick yellow wiring tape out of the camera internal housing component.
    Pergunte ao FixBot
    Comentar
  19. Olympus D590 Lens Replacement, Lens: passo 19, imagem 1 %32
    • Flip the camera so you are looking at the back.
    • Looking at the back of the camera, remove the 3 screws behind the camera lens.
    Pergunte ao FixBot
    Comentar
  20. Olympus D590 Lens Replacement: passo 20, imagem 1 %32
    • Flip the camera so that the front lens is facing up.
    • Disconnect the lens from the logic board.
    Pergunte ao FixBot
    Comentar
  21. Olympus D590 Lens Replacement: passo 21, imagem 1 %32
    • Flip the camera back over so that the back of the camera is facing you, and the lens in facing away.
    • Disconnect the wire that connects the logic board to the lens assembly.
    • Gently pull back on the wire to disconnect it safely.
    Pergunte ao FixBot
    Comentar
  22. Olympus D590 Lens Replacement: passo 22, imagem 1 %32
    • Flip the camera back around so that the front is facing you.
    • Carefully lift the lens assembly out of the camera.
    Pergunte ao FixBot
    Comentar
Conclusão
Joshua
Membro desde: 04/15/10
7 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 28-23, Regan Spring 2010 Membro de Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 42
Ao todo: 2,966
