Ir para o conteúdo principal
Olympus 850SW Memory Card Replacement
    1. Olympus 850SW Memory Card Replacement, Memory Card: passo 1, imagem 1 %32
      • Locate the memory card latch/ battery latch on the bottom panel of the camera and open it.
      • Make sure to remove the battery before trying to remove the memory card.
      Pergunte ao FixBot
      Comentar
    2. Olympus 850SW Memory Card Replacement: passo 2, imagem 1 %32
      • Hold the memory card so that the pointed wedge is facing up and the sticker is facing the front of the camera.
      Pergunte ao FixBot
      Comentar
    3. Olympus 850SW Memory Card Replacement: passo 3, imagem 1 %32
      • Hold the card so that the thicker end of it is to the right, and the flat end is facing the bottom of the camera.
      • Insert the card into the compartment fully until it clicks into place.
      Pergunte ao FixBot
      Comentar
    4. Olympus 850SW Memory Card Replacement: passo 4, imagem 1 %32
      • Close the memory card latch/ battery latch.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
1Comentário do guia
How much gigabytes can I use on an Olympus 850 SW?
Yuan - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 55
Ao todo: 3,054
