Ir para o conteúdo principal
Oculus Rift Development Kit 2 Display Screen Replacement
O que você precisa
  1. Oculus Rift Development Kit 2 Display Screen Replacement, Eye Relief Adjustment Screw: passo 1, imagem 1 %32 Oculus Rift Development Kit 2 Display Screen Replacement, Eye Relief Adjustment Screw: passo 1, imagem 2 %32 Oculus Rift Development Kit 2 Display Screen Replacement, Eye Relief Adjustment Screw: passo 1, imagem 3 %32
    • Remove front cover plate.
    • Unplug the USB and HDMI cables from the Oculus Rift DK2.
  2. Oculus Rift Development Kit 2 Display Screen Replacement: passo 2, imagem 1 %32 Oculus Rift Development Kit 2 Display Screen Replacement: passo 2, imagem 2 %32 Oculus Rift Development Kit 2 Display Screen Replacement: passo 2, imagem 3 %32
    • Remove the four 3/8" Phillips #0 screws from the inner portion of the headset.
  3. Oculus Rift Development Kit 2 Display Screen Replacement: passo 3, imagem 1 %32 Oculus Rift Development Kit 2 Display Screen Replacement: passo 3, imagem 2 %32
    • With the screws removed, gently pull the headband frame apart from the headset.
  4. Oculus Rift Development Kit 2 Display Screen Replacement, Remove Lens: passo 4, imagem 1 %32 Oculus Rift Development Kit 2 Display Screen Replacement, Remove Lens: passo 4, imagem 2 %32
    • With the Oculus facing up, twist the right lens clockwise and lift it out. Repeat for the left lens twisting counterclockwise instead.
  5. Oculus Rift Development Kit 2 Display Screen Replacement, Headset Motherboard: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, carefully lift the four rubber plugs as shown. They are a bit snug and you may need to jiggle them free with the tweezers.
  6. Oculus Rift Development Kit 2 Display Screen Replacement: passo 6, imagem 1 %32
    • Remove the four 3/8" screws attaching the eyewear enclosure to the front casing.
    • Read the next step before removing the faceplate!
  7. Oculus Rift Development Kit 2 Display Screen Replacement: passo 7, imagem 1 %32 Oculus Rift Development Kit 2 Display Screen Replacement: passo 7, imagem 2 %32
    • Carefully separate the faceplate and the cover. Gently rest the cover plate on top of the faceplate as shown in the pictures.
    • Do not use excessive force when separating these two pieces. There is a delicate ribbon cable connected to each.
  8. Oculus Rift Development Kit 2 Display Screen Replacement: passo 8, imagem 1 %32 Oculus Rift Development Kit 2 Display Screen Replacement: passo 8, imagem 2 %32
    • Gently pull out the small side tabs on the ribbon cable connector as shown to release the cable.
    • Push the tabs away from you, with the headset oriented as pictured. Carefully slide the ribbon cable out.
    • The headset should now be two separate pieces.
  9. Oculus Rift Development Kit 2 Display Screen Replacement: passo 9, imagem 1 %32 Oculus Rift Development Kit 2 Display Screen Replacement: passo 9, imagem 2 %32 Oculus Rift Development Kit 2 Display Screen Replacement: passo 9, imagem 3 %32
    • Unscrew the three 1/4" Phillips #00 screws as pictured and use the tweezers to lift them out.
  10. Oculus Rift Development Kit 2 Display Screen Replacement: passo 10, imagem 1 %32
    • Lift the tape and gently pry up the video data ribbon cable using the plastic opening tool as shown.
  11. Oculus Rift Development Kit 2 Display Screen Replacement: passo 11, imagem 1 %32 Oculus Rift Development Kit 2 Display Screen Replacement: passo 11, imagem 2 %32 Oculus Rift Development Kit 2 Display Screen Replacement: passo 11, imagem 3 %32
    • Gently pry back the motherboard clips to release the motherboard. The motherboard should now lift free.
  12. Oculus Rift Development Kit 2 Display Screen Replacement, Display Screen: passo 12, imagem 1 %32 Oculus Rift Development Kit 2 Display Screen Replacement, Display Screen: passo 12, imagem 2 %32 Oculus Rift Development Kit 2 Display Screen Replacement, Display Screen: passo 12, imagem 3 %32
    • Remove the six 1/4" Phillips #1 screws as shown. There should be two on each short side, and one on each long side.
    • Gently lift the plastic screen holder and display screen away from the remaining piece of the faceplate.
Conclusão
4 outras pessoas executaram este guia.
Adam
Membro desde: 01/20/15
661 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 18-5, Maness Winter 2015 Membro de Cal Poly, Team 18-5, Maness Winter 2015
CPSU-MANESS-W15S18G5
4 Membros
Autoria de 6 guias
2Comentários do guia
It's possible to use the Samsung Galaxy Note 4 screen?
Lauro Adriano Freitas - Responder Compartilhar
moldovancasyan19 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 41
Ao todo: 3,155
