Ir para o conteúdo principal
Oculus Rift Development Kit 2 Display Screen Replacement
O que você precisa
  1. Oculus Rift Development Kit 2 Display Screen Replacement, Eye Relief Adjustment Screw: passo 1, imagem 1 %32 Oculus Rift Development Kit 2 Display Screen Replacement, Eye Relief Adjustment Screw: passo 1, imagem 2 %32 Oculus Rift Development Kit 2 Display Screen Replacement, Eye Relief Adjustment Screw: passo 1, imagem 3 %32
    • Remove front cover plate.
    • Unplug the USB and HDMI cables from the Oculus Rift DK2.
    Pergunte ao FixBot
    Comentar
  2. Oculus Rift Development Kit 2 Display Screen Replacement: passo 2, imagem 1 %32 Oculus Rift Development Kit 2 Display Screen Replacement: passo 2, imagem 2 %32 Oculus Rift Development Kit 2 Display Screen Replacement: passo 2, imagem 3 %32
    • Remove the four 3/8" Phillips #0 screws from the inner portion of the headset.
    Pergunte ao FixBot
    Comentar
  3. Oculus Rift Development Kit 2 Display Screen Replacement: passo 3, imagem 1 %32 Oculus Rift Development Kit 2 Display Screen Replacement: passo 3, imagem 2 %32
    • With the screws removed, gently pull the headband frame apart from the headset.
    Pergunte ao FixBot
    Comentar
  4. Oculus Rift Development Kit 2 Display Screen Replacement, Remove Lens: passo 4, imagem 1 %32 Oculus Rift Development Kit 2 Display Screen Replacement, Remove Lens: passo 4, imagem 2 %32
    • With the Oculus facing up, twist the right lens clockwise and lift it out. Repeat for the left lens twisting counterclockwise instead.
    Pergunte ao FixBot
    Comentar
  5. Oculus Rift Development Kit 2 Display Screen Replacement, Headset Motherboard: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, carefully lift the four rubber plugs as shown. They are a bit snug and you may need to jiggle them free with the tweezers.
    Pergunte ao FixBot
    Comentar
  6. Oculus Rift Development Kit 2 Display Screen Replacement: passo 6, imagem 1 %32
    • Remove the four 3/8" screws attaching the eyewear enclosure to the front casing.
    • Read the next step before removing the faceplate!
    Pergunte ao FixBot
    Comentar
  7. Oculus Rift Development Kit 2 Display Screen Replacement: passo 7, imagem 1 %32 Oculus Rift Development Kit 2 Display Screen Replacement: passo 7, imagem 2 %32
    • Carefully separate the faceplate and the cover. Gently rest the cover plate on top of the faceplate as shown in the pictures.
    • Do not use excessive force when separating these two pieces. There is a delicate ribbon cable connected to each.
    Pergunte ao FixBot
    Comentar
  8. Oculus Rift Development Kit 2 Display Screen Replacement: passo 8, imagem 1 %32 Oculus Rift Development Kit 2 Display Screen Replacement: passo 8, imagem 2 %32
    • Gently pull out the small side tabs on the ribbon cable connector as shown to release the cable.
    • Push the tabs away from you, with the headset oriented as pictured. Carefully slide the ribbon cable out.
    • The headset should now be two separate pieces.
    Pergunte ao FixBot
    Comentar
  9. Oculus Rift Development Kit 2 Display Screen Replacement: passo 9, imagem 1 %32 Oculus Rift Development Kit 2 Display Screen Replacement: passo 9, imagem 2 %32 Oculus Rift Development Kit 2 Display Screen Replacement: passo 9, imagem 3 %32
    • Unscrew the three 1/4" Phillips #00 screws as pictured and use the tweezers to lift them out.
    Pergunte ao FixBot
    Comentar
  10. Oculus Rift Development Kit 2 Display Screen Replacement: passo 10, imagem 1 %32
    • Lift the tape and gently pry up the video data ribbon cable using the plastic opening tool as shown.
    Pergunte ao FixBot
    Comentar
  11. Oculus Rift Development Kit 2 Display Screen Replacement: passo 11, imagem 1 %32 Oculus Rift Development Kit 2 Display Screen Replacement: passo 11, imagem 2 %32 Oculus Rift Development Kit 2 Display Screen Replacement: passo 11, imagem 3 %32
    • Gently pry back the motherboard clips to release the motherboard. The motherboard should now lift free.
    Pergunte ao FixBot
    Comentar
  12. Oculus Rift Development Kit 2 Display Screen Replacement, Display Screen: passo 12, imagem 1 %32 Oculus Rift Development Kit 2 Display Screen Replacement, Display Screen: passo 12, imagem 2 %32 Oculus Rift Development Kit 2 Display Screen Replacement, Display Screen: passo 12, imagem 3 %32
    • Remove the six 1/4" Phillips #1 screws as shown. There should be two on each short side, and one on each long side.
    • Gently lift the plastic screen holder and display screen away from the remaining piece of the faceplate.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
Adam
Membro desde: 01/20/15
661 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 18-5, Maness Winter 2015 Membro de Cal Poly, Team 18-5, Maness Winter 2015
CPSU-MANESS-W15S18G5
4 Membros
Autoria de 6 guias
2Comentários do guia
It's possible to use the Samsung Galaxy Note 4 screen?
Lauro Adriano Freitas - Responder Compartilhar
moldovancasyan19 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 38
Ao todo: 3,278
