Ir para o conteúdo principal
Oculus Rift DK1 Display Replacement
O que você precisa
  1. Oculus Rift DK1 Display Replacement, Lens: passo 1, imagem 1 %32 Oculus Rift DK1 Display Replacement, Lens: passo 1, imagem 2 %32
    • To remove the lenses, turn the right lens clockwise a quarter turn and the left lens counter-clockwise a quarter turn.
    Pergunte ao FixBot
    Comentar
  2. Oculus Rift DK1 Display Replacement, Display: passo 2, imagem 1 %32 Oculus Rift DK1 Display Replacement, Display: passo 2, imagem 2 %32
    • Use a Phillips #01 screwdriver to unscrew the four 9 mm Phillips #01 screws. (Two screws are shown in the picture, and two more screws are on the left side across from the right screws.)
    Pergunte ao FixBot
    Comentar
  3. Oculus Rift DK1 Display Replacement: passo 3, imagem 1 %32 Oculus Rift DK1 Display Replacement: passo 3, imagem 2 %32 Oculus Rift DK1 Display Replacement: passo 3, imagem 3 %32
    • Carefully lift the headstrap from the display. The two parts should separate easily enough with some force.
    • Once the headstrap assembly and display box are separated, the headstrap assembly can be set aside. You will be working with the display box for the rest of this guide!
    Pergunte ao FixBot
    Comentar
  4. Oculus Rift DK1 Display Replacement: passo 4, imagem 1 %32 Oculus Rift DK1 Display Replacement: passo 4, imagem 2 %32
    • Using the plastic opening tool, pry open the display box to reveal the LCD (Liquid Crystal Display) screen. Run the plastic opening tool around all four edges. Prying open the box may take a good amount of force.
    Pergunte ao FixBot
    Comentar
  5. Oculus Rift DK1 Display Replacement: passo 5, imagem 1 %32 Oculus Rift DK1 Display Replacement: passo 5, imagem 2 %32 Oculus Rift DK1 Display Replacement: passo 5, imagem 3 %32
    • Run the plastic opening tool along the bottom edge under the LCD screen to separate the adhesive holding the LCD to the display box.
    • Lift the screen up to reveal the wires and circuit board.
    • Ensure that all wires are in the right place upon reassembly.
    Pergunte ao FixBot
    Comentar
  6. Oculus Rift DK1 Display Replacement: passo 6, imagem 1 %32 Oculus Rift DK1 Display Replacement: passo 6, imagem 2 %32
    • Remove the wires from the circuit board on the LCD display using your fingernail or a plastic opening tool. This may take some pushing and pulling of the plastic piece.
    • Don't pull on the wires! Be sure to only pry the plastic part.
    • You can now completely separate the LCD screen from the rest of the device!
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 70-5, Forte Winter 2015 Membro de Cal Poly, Team 70-5, Forte Winter 2015
CPSU-FORTE-W15S70G5
4 Membros
Autoria de 6 guias
1Comentário do guia
testtesttesttest
d
cybname - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 52
Ao todo: 4,246
