Ir para o conteúdo principal
ORFELD EV-660-S222 Battery LED Board Replacement
O que você precisa
    1. ORFELD EV-660-S222 Battery LED Board Replacement, Battery LED Board: passo 1, imagem 1 %32
      • Separate the dust cover and the motor from the vacuum body by pressing the eject button.
      Pergunte ao FixBot
      Comentar
    2. ORFELD EV-660-S222 Battery LED Board Replacement: passo 2, imagem 1 %32 ORFELD EV-660-S222 Battery LED Board Replacement: passo 2, imagem 2 %32
      • Place the vacuum on its side, with the screws facing towards you.
      • Remove the 11.5 mm screws using a Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. ORFELD EV-660-S222 Battery LED Board Replacement: passo 3, imagem 1 %32 ORFELD EV-660-S222 Battery LED Board Replacement: passo 3, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Using tweezers, remove the sticker connecting the two halves.
      • Use the opening pick to gently separate the top half and the bottom half of the vacuum.
      • Press the blue buttons near the sides of the battery LEDs to remove the top half.
      Pergunte ao FixBot
      Comentar
    4. ORFELD EV-660-S222 Battery LED Board Replacement: passo 4, imagem 1 %32 ORFELD EV-660-S222 Battery LED Board Replacement: passo 4, imagem 2 %32
      • Slide out the charging port.
      Pergunte ao FixBot
      Comentar
    5. ORFELD EV-660-S222 Battery LED Board Replacement: passo 5, imagem 1 %32
      • Lift the battery slightly to reveal the pin connectors.
      • Gently disconnect the six-pin connector that connects to the power button and battery LEDs.
      Pergunte ao FixBot
      Comentar
    6. ORFELD EV-660-S222 Battery LED Board Replacement: passo 6, imagem 1 %32 ORFELD EV-660-S222 Battery LED Board Replacement: passo 6, imagem 2 %32 ORFELD EV-660-S222 Battery LED Board Replacement: passo 6, imagem 3 %32
      • Slide out the battery LEDs from the compartment.
      • Remove the plastic LED cover from the LED board.
      Pergunte ao FixBot
      Comentar
    7. ORFELD EV-660-S222 Battery LED Board Replacement: passo 7, imagem 1 %32
      • Desolder the LED board from the wires.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 39
Ao todo: 1,146
