Ir para o conteúdo principal
OPPO N1 Motherboard Replacement
O que você precisa
  1. OPPO N1 Motherboard Replacement, Rear Case: passo 1, imagem 1 %32
    • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
    Pergunte ao FixBot
    Comentar
  2. OPPO N1 Motherboard Replacement: passo 2, imagem 1 %32 OPPO N1 Motherboard Replacement: passo 2, imagem 2 %32
    • In the photo we rotated the phone ninety degrees counterclockwise.
    • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
    • The rear case should then come free.
    Pergunte ao FixBot
    Comentar
  3. OPPO N1 Motherboard Replacement, Battery: passo 3, imagem 1 %32 OPPO N1 Motherboard Replacement, Battery: passo 3, imagem 2 %32
    • Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
    Pergunte ao FixBot
    Comentar
  4. OPPO N1 Motherboard Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use the tweezers or your fingers to remove the sliver plates.
    Pergunte ao FixBot
    Comentar
  5. OPPO N1 Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the black plate with your fingers.
    Pergunte ao FixBot
    Comentar
  6. OPPO N1 Motherboard Replacement: passo 6, imagem 1 %32 OPPO N1 Motherboard Replacement: passo 6, imagem 2 %32 OPPO N1 Motherboard Replacement: passo 6, imagem 3 %32
    • Use tweezers or your fingers to pull up the connector tabs.
    Pergunte ao FixBot
    Comentar
  7. OPPO N1 Motherboard Replacement: passo 7, imagem 1 %32 OPPO N1 Motherboard Replacement: passo 7, imagem 2 %32
    • Use the blue opening tool to carefully pry the battery from the sticky tape that attaches it to the device.
    Pergunte ao FixBot
    Comentar
  8. OPPO N1 Motherboard Replacement, Motherboard: passo 8, imagem 1 %32
    • Use tweezers or fingers to remove the three connector tabs.
    Pergunte ao FixBot
    Comentar
  9. OPPO N1 Motherboard Replacement: passo 9, imagem 1 %32 OPPO N1 Motherboard Replacement: passo 9, imagem 2 %32
    • Use tweezers or your fingers to remove the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Joshua Stone
Membro desde: 09/26/14
1.067 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 13-5, Staggers Fall 2014 Membro de USF Tampa, Team 13-5, Staggers Fall 2014
USFT-STAGGERS-F14S13G5
3 Membros
Autoria de 14 guias
3Comentários do guia
how much is the mother board for oppo f1
gillianrain28 - Responder Compartilhar
Hi,I used a wrong car charger on my oppo n1 in the wrong port and since then my phone went off and never turns on.
Can I I sent the unit to you for repair?
danjuma kolo - Responder Compartilhar
I used a round pin car charger at the earpiece port of my oppo n1…and the phone went off…tiok it for repair but still not working…can u be off assistance
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 38
Ao todo: 5,819
