Ir para o conteúdo principal
OLPC XO-4 Touch Touchpad Controller Replacement
O que você precisa
    1. OLPC XO-4 Touch Touchpad Controller Replacement, Battery: passo 1, imagem 1 %32
      • Turn the laptop upside-down, with the handle facing away from you.
      Pergunte ao FixBot
      Comentar
    2. OLPC XO-4 Touch Touchpad Controller Replacement: passo 2, imagem 1 %32 OLPC XO-4 Touch Touchpad Controller Replacement: passo 2, imagem 2 %32
      • Pull the lock tabs towards the green outer edges of the laptop.
      • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
      Pergunte ao FixBot
      Comentar
    3. OLPC XO-4 Touch Touchpad Controller Replacement: passo 3, imagem 1 %32 OLPC XO-4 Touch Touchpad Controller Replacement: passo 3, imagem 2 %32
      • Lift up on the middle of the battery to remove it from the device.
      Pergunte ao FixBot
      Comentar
    1. OLPC XO-4 Touch Touchpad Controller Replacement, Keyboard: passo 4, imagem 1 %32 OLPC XO-4 Touch Touchpad Controller Replacement, Keyboard: passo 4, imagem 2 %32
      • Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
      Pergunte ao FixBot
      Comentar
    2. OLPC XO-4 Touch Touchpad Controller Replacement: passo 5, imagem 1 %32 OLPC XO-4 Touch Touchpad Controller Replacement: passo 5, imagem 2 %32 OLPC XO-4 Touch Touchpad Controller Replacement: passo 5, imagem 3 %32
      • Flip the laptop over to its normal position.
      • Lift the two antennas on both sides to unlock the screen.
      • Open the laptop.
      Pergunte ao FixBot
      Comentar
    3. OLPC XO-4 Touch Touchpad Controller Replacement: passo 6, imagem 1 %32 OLPC XO-4 Touch Touchpad Controller Replacement: passo 6, imagem 2 %32
      • Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom.
      • Gently lift up on the back of the keyboard.
      • Pull the keyboard up far enough to expose the ribbon cable.
      Pergunte ao FixBot
      Comentar
    4. OLPC XO-4 Touch Touchpad Controller Replacement: passo 7, imagem 1 %32 OLPC XO-4 Touch Touchpad Controller Replacement: passo 7, imagem 2 %32
      • Gently lift up on the black connector to release the ribbon cable.
      • Gently pull the blue plastic tab up and away from the black connector.
      • Remove the keyboard from the laptop.
      Pergunte ao FixBot
      Comentar
    1. OLPC XO-4 Touch Touchpad Controller Replacement, Lower Case: passo 8, imagem 1 %32 OLPC XO-4 Touch Touchpad Controller Replacement, Lower Case: passo 8, imagem 2 %32
      • Close and flip the laptop over so you are looking at the battery compartment
      • Remove the five 4mm Phillips #1 screws from inside the battery compartment
      Pergunte ao FixBot
      Comentar
    2. OLPC XO-4 Touch Touchpad Controller Replacement: passo 9, imagem 1 %32 OLPC XO-4 Touch Touchpad Controller Replacement: passo 9, imagem 2 %32 OLPC XO-4 Touch Touchpad Controller Replacement: passo 9, imagem 3 %32
      • Flip the laptop over, showing the top of the device.
      • Open the laptop and rotate the screen ninety degrees.
      • Tilt the screen so the lower right corner of the screen is closer to the lower case.
      Pergunte ao FixBot
      Comentar
    3. OLPC XO-4 Touch Touchpad Controller Replacement: passo 10, imagem 1 %32 OLPC XO-4 Touch Touchpad Controller Replacement: passo 10, imagem 2 %32 OLPC XO-4 Touch Touchpad Controller Replacement: passo 10, imagem 3 %32
      • Push in and lift up on the keyboard edge of the white handle piece.
      • Pull the piece towards yourself to remove it from the laptop.
      Pergunte ao FixBot
      Comentar
    4. OLPC XO-4 Touch Touchpad Controller Replacement: passo 11, imagem 1 %32
      • Remove the four 4mm Phillips #1 screws attaching the green trim to the body of the computer.
      Pergunte ao FixBot
      Comentar
    5. OLPC XO-4 Touch Touchpad Controller Replacement: passo 12, imagem 1 %32 OLPC XO-4 Touch Touchpad Controller Replacement: passo 12, imagem 2 %32
      • Pry off the rear green trim piece.
      Pergunte ao FixBot
      Comentar
    6. OLPC XO-4 Touch Touchpad Controller Replacement: passo 13, imagem 1 %32 OLPC XO-4 Touch Touchpad Controller Replacement: passo 13, imagem 2 %32 OLPC XO-4 Touch Touchpad Controller Replacement: passo 13, imagem 3 %32
      • Be careful not to pull the bottom portion of the laptop completely off, as there is a cable connecting it to the laptop.
      • Slide the green trim pieces away from the screen.
      • This should release the entire bottom portion of the laptop.
      Pergunte ao FixBot
      Comentar
    7. OLPC XO-4 Touch Touchpad Controller Replacement: passo 14, imagem 1 %32 OLPC XO-4 Touch Touchpad Controller Replacement: passo 14, imagem 2 %32 OLPC XO-4 Touch Touchpad Controller Replacement: passo 14, imagem 3 %32
      • Unplug the cable from the mouse buttons controller to completely remove the lower frame from the device.
      Pergunte ao FixBot
      Comentar
    8. OLPC XO-4 Touch Touchpad Controller Replacement: passo 15, imagem 1 %32 OLPC XO-4 Touch Touchpad Controller Replacement: passo 15, imagem 2 %32
      • Rotate the entire lower assembly up slightly, and pull it away from the screen to free it from the screen hinge.
      • There may be some adhesive holding the cable to the metal plate. Gently pull the cable off of the plate if it is stuck.
      Pergunte ao FixBot
      Comentar
    1. OLPC XO-4 Touch Touchpad Controller Replacement, Mouse Buttons Controller: passo 16, imagem 1 %32 OLPC XO-4 Touch Touchpad Controller Replacement, Mouse Buttons Controller: passo 16, imagem 2 %32 OLPC XO-4 Touch Touchpad Controller Replacement, Mouse Buttons Controller: passo 16, imagem 3 %32
      • You should now be looking at the bottom of the lower case.
      • Remove the eight 4mm Phillips #1 screws attaching the green trim pieces to the lower frame.
      • Pry off the front and side trim pieces.
      Pergunte ao FixBot
      Comentar
    2. OLPC XO-4 Touch Touchpad Controller Replacement: passo 17, imagem 1 %32
      • Remove the two 4mm Phillips #1 screws that attach the mouse buttons controller to the lower frame.
      Pergunte ao FixBot
      Comentar
    3. OLPC XO-4 Touch Touchpad Controller Replacement: passo 18, imagem 1 %32 OLPC XO-4 Touch Touchpad Controller Replacement: passo 18, imagem 2 %32 OLPC XO-4 Touch Touchpad Controller Replacement: passo 18, imagem 3 %32
      • Disconnect the ribbon cable attached to the keyboard compartment.
      • Unplug the ribbon cable between the touchpad and the mouse buttons controller.
      • Remove the mouse buttons controller from the device.
      Pergunte ao FixBot
      Comentar
    1. OLPC XO-4 Touch Touchpad Controller Replacement, Touchpad Controller: passo 19, imagem 1 %32
      • Remove the two 4mm Phillips screws that attach the metal plate to the touchpad assembly.
      • Be sure not to lose the silver magnet in the lower right corner of the touchpad assembly.
      Pergunte ao FixBot
      Comentar
    2. OLPC XO-4 Touch Touchpad Controller Replacement: passo 20, imagem 1 %32 OLPC XO-4 Touch Touchpad Controller Replacement: passo 20, imagem 2 %32 OLPC XO-4 Touch Touchpad Controller Replacement: passo 20, imagem 3 %32
      • Remove the silver contact tape from the metal plate.
      • Lift the metal plate off of the touchpad assembly.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 3-30, Amido Winter 2013 Membro de Cal Poly, Team 3-30, Amido Winter 2013
CPSU-AMIDO-W13S3G30
3 Membros
Autoria de 42 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 29
Ao todo: 862
