Ir para o conteúdo principal
OLPC XO-4 Touch Camera Replacement
O que você precisa
    1. OLPC XO-4 Touch Camera Replacement, Battery: passo 1, imagem 1 %32
      • Turn the laptop upside-down, with the handle facing away from you.
      Pergunte ao FixBot
      Comentar
    2. OLPC XO-4 Touch Camera Replacement: passo 2, imagem 1 %32 OLPC XO-4 Touch Camera Replacement: passo 2, imagem 2 %32
      • Pull the lock tabs towards the green outer edges of the laptop.
      • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
      Pergunte ao FixBot
      Comentar
    3. OLPC XO-4 Touch Camera Replacement: passo 3, imagem 1 %32 OLPC XO-4 Touch Camera Replacement: passo 3, imagem 2 %32
      • Lift up on the middle of the battery to remove it from the device.
      Pergunte ao FixBot
      Comentar
    1. OLPC XO-4 Touch Camera Replacement, Screen Frame: passo 4, imagem 1 %32 OLPC XO-4 Touch Camera Replacement, Screen Frame: passo 4, imagem 2 %32 OLPC XO-4 Touch Camera Replacement, Screen Frame: passo 4, imagem 3 %32
      • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
      • Rotate the screen 180° and remove the other two screws.
      • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
      Pergunte ao FixBot
      Comentar
    2. OLPC XO-4 Touch Camera Replacement: passo 5, imagem 1 %32 OLPC XO-4 Touch Camera Replacement: passo 5, imagem 2 %32 OLPC XO-4 Touch Camera Replacement: passo 5, imagem 3 %32
      • Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
      • Repeat the step above for the panel on the other side.
      Pergunte ao FixBot
      Comentar
    3. OLPC XO-4 Touch Camera Replacement: passo 6, imagem 1 %32
      • Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
      • Gently lift up the lower part of the frame and pull it down to free the screen frame.
      Pergunte ao FixBot
      Comentar
    4. OLPC XO-4 Touch Camera Replacement: passo 7, imagem 1 %32 OLPC XO-4 Touch Camera Replacement: passo 7, imagem 2 %32
      • Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
      Pergunte ao FixBot
      Comentar
    1. OLPC XO-4 Touch Camera Replacement, Screen: passo 8, imagem 1 %32
      • Remove the four 7.62mm screws using a Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. OLPC XO-4 Touch Camera Replacement: passo 9, imagem 1 %32 OLPC XO-4 Touch Camera Replacement: passo 9, imagem 2 %32
      • Be careful not to pull the screen out too far. There are two ribbon cables attached to the screen, and they can easily break.
      • Carefully lift the screen out.
      Pergunte ao FixBot
      Comentar
    3. OLPC XO-4 Touch Camera Replacement: passo 10, imagem 1 %32 OLPC XO-4 Touch Camera Replacement: passo 10, imagem 2 %32 OLPC XO-4 Touch Camera Replacement: passo 10, imagem 3 %32
      • Notice that the laptop in this picture has been turned 180° with the antennas now below the screen.
      • For each ribbon cable, lift up the black connector and gently pull the ribbon cables out by the plastic tabs.
      Pergunte ao FixBot
      Comentar
    4. OLPC XO-4 Touch Camera Replacement: passo 11, imagem 1 %32
      • Remove the screen from the laptop.
      Pergunte ao FixBot
      Comentar
    1. OLPC XO-4 Touch Camera Replacement, Back Cover: passo 12, imagem 1 %32
      • Remove the four 6mm screws using a Phillips #1 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. OLPC XO-4 Touch Camera Replacement: passo 13, imagem 1 %32 OLPC XO-4 Touch Camera Replacement: passo 13, imagem 2 %32
      • Rotate the top half of the laptop so that the back cover is facing you.
      • Pull up the tabs on the lower part of the back cover and pull it down and away from the antennas.
      • Remove the back cover by gently lifting it off of the laptop.
      Pergunte ao FixBot
      Comentar
    1. OLPC XO-4 Touch Camera Replacement, Motherboard: passo 14, imagem 1 %32 OLPC XO-4 Touch Camera Replacement, Motherboard: passo 14, imagem 2 %32 OLPC XO-4 Touch Camera Replacement, Motherboard: passo 14, imagem 3 %32
      • Remove the four black 4mm screws from the metal cover using a Phillips #1 screwdriver.
      • Remove the metal cover from the laptop.
      Pergunte ao FixBot
      Comentar
    2. OLPC XO-4 Touch Camera Replacement: passo 15, imagem 1 %32 OLPC XO-4 Touch Camera Replacement: passo 15, imagem 2 %32 OLPC XO-4 Touch Camera Replacement: passo 15, imagem 3 %32
      • Pull the connectors out by holding the plastic tabs and not the wires.
      • Unplug the three wires connecting the motherboard to the bottom half of the laptop.
      • Unplug the two speaker wires from the motherboard.
      Pergunte ao FixBot
      Comentar
    3. OLPC XO-4 Touch Camera Replacement: passo 16, imagem 1 %32 OLPC XO-4 Touch Camera Replacement: passo 16, imagem 2 %32 OLPC XO-4 Touch Camera Replacement: passo 16, imagem 3 %32
      • Turn the device over to where the screen used to be.
      • Pull out ribbon cable by holding the purple plastic tab.
      • Pull out connector with the black and white wire by holding plastic tab.
      Pergunte ao FixBot
      Comentar
    4. OLPC XO-4 Touch Camera Replacement: passo 17, imagem 1 %32 OLPC XO-4 Touch Camera Replacement: passo 17, imagem 2 %32
      • Move the motherboard slightly to the left so that the audio input and output jacks are out of the frame.
      • Pull the motherboard out of the laptop.
      Pergunte ao FixBot
      Comentar
    1. OLPC XO-4 Touch Camera Replacement, Camera: passo 18, imagem 1 %32
      • When unplugging ribbon cables, hold the plastic tab instead of the cable itself.
      • Unplug the ribbon cable from the connector on the underside of the motherboard.
      • A thin layer of adhesive binds the camera to the motherboard.
      • Pull the camera away from the motherboard to remove it.
      Pergunte ao FixBot
      Comentar
Conclusão
Ji Kim
Membro desde: 01/25/13
66 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 3-29, Amido Winter 2013 Membro de Cal Poly, Team 3-29, Amido Winter 2013
CPSU-AMIDO-W13S3G29
4 Membros
Autoria de 60 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 33
Ao todo: 670
