Ir para o conteúdo principal
Nvidia Shield Tablet Touchscreen Controller Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
    1. Nvidia Shield Tablet Touchscreen Controller Replacement, Rear Case: passo 1, imagem 1 %32 Nvidia Shield Tablet Touchscreen Controller Replacement, Rear Case: passo 1, imagem 2 %32
      • First, remove the stylus from your tablet.
      Pergunte ao FixBot
      Comentar
    2. Nvidia Shield Tablet Touchscreen Controller Replacement: passo 2, imagem 1 %32 Nvidia Shield Tablet Touchscreen Controller Replacement: passo 2, imagem 2 %32 Nvidia Shield Tablet Touchscreen Controller Replacement: passo 2, imagem 3 %32
      Ferramenta utilizada neste passo:
      Anti-Static Wrist Strap
      $7.95
      • Set the tablet so the buttons, microSD, and stylus port are facing you.
      • Open the microSD slot.
      • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
      • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
      Pergunte ao FixBot
      Comentar
    3. Nvidia Shield Tablet Touchscreen Controller Replacement: passo 3, imagem 1 %32 Nvidia Shield Tablet Touchscreen Controller Replacement: passo 3, imagem 2 %32
      • As you remove your case, be aware of small clips along the edges.
      • Finally, set the old casing aside.
      Pergunte ao FixBot
      Comentar
    1. Nvidia Shield Tablet Touchscreen Controller Replacement, Touchscreen Controller: passo 4, imagem 1 %32 Nvidia Shield Tablet Touchscreen Controller Replacement, Touchscreen Controller: passo 4, imagem 2 %32
      $7.95
      • Peel away the tape covering the top right side of the motherboard. The plastic opening tools are useful in nudging the tape off.
      • Make sure you are using your anti-static wrist strap.
      Pergunte ao FixBot
      Comentar
    2. Nvidia Shield Tablet Touchscreen Controller Replacement: passo 5, imagem 1 %32 Nvidia Shield Tablet Touchscreen Controller Replacement: passo 5, imagem 2 %32
      • Using the precision tweezers, gently remove the touchscreen controller from its port.
      Pergunte ao FixBot
      Comentar
Conclusão
Molly Bauer
Membro desde: 08/27/15
1.478 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 2-2, Blackwell Fall 2015 Membro de USF Tampa, Team 2-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G2
3 Membros
Autoria de 11 guias
4Comentários do guia
how to change this controller ???? he is not removable !!! where to buy it?
Tom - Responder Compartilhar
How are you supposed to replace this part if it's connected to the Touchscreen panel by a flat ribbon cable. The pictures show the touchscreen controller that has been severed/cut by where the flat cable goes 90 degrees towards the touchscreen, you cannot just replace this part by itself as shown in the pictures. WTF????
Luis Nido - Responder Compartilhar
My Thoughts exactly. Mine has one connector that is easily removed, the smaller end. The large wide end is up under a metal frame. I gave a gentle tug, but apparently its glued or sealed. Now to figure out how to remove it. Guessing a heat gun to the glass is the easiest way? No coming apart from the back/inside!
The Watson - Responder Compartilhar
why is this still up. you can’t replace this part so the title is misleading. This part is torn easy you must remove the board from the tablet with the touch cable connector unlatched but the cable still in. if you try to bull it out first it rips.
MYdeviceRepair - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 32
Ao todo: 3,547
