Ir para o conteúdo principal
Nvidia Shield TV 1st Generation Controller Battery Replacement
O que você precisa
  1. Nvidia Shield TV 1st Generation Controller Battery Replacement, Controller Battery: passo 1, imagem 1 %32 Nvidia Shield TV 1st Generation Controller Battery Replacement, Controller Battery: passo 1, imagem 2 %32
    • Remove the indicated six screws using the T6 Torx screwdriver.
    Pergunte ao FixBot
    Comentar
  2. Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 2, imagem 1 %32 Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 2, imagem 2 %32
    • Use the plastic opening tool to pry the face of the controller away from the body.
    • Make sure the controller is face down during this step as the buttons can easily fall out.
    Pergunte ao FixBot
    Comentar
  3. Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 3, imagem 1 %32
    • Carefully remove the indicated ribbon wires from the face of the controller.
    Pergunte ao FixBot
    Comentar
  4. Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 4, imagem 1 %32 Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    $3.99
    • Use the angled tweezers to remove the vibration motor cable, moving it upward from its socket.
    • Lift the vibration motor out of the front case.
    • Repeat for the other side.
    • Use the angled tweezers to remove the battery cable, moving it upward from its socket.
    Pergunte ao FixBot
    Comentar
  5. Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 5, imagem 1 %32 Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 5, imagem 2 %32 Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 5, imagem 3 %32
    • Using the T6 Torx screwdriver, remove the indicated eight screws from the logic board.
    • Lift the logic board away from the front case.
    Pergunte ao FixBot
    Comentar
  6. Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 6, imagem 1 %32 Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 6, imagem 2 %32 Nvidia Shield TV 1st Generation Controller Battery Replacement: passo 6, imagem 3 %32
    • Using the T6 Torx screwdriver, remove the indicated four screws from the panel.
    • Remove the panel from the front case.
    • Lift the battery from the front case to remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
12 outras pessoas executaram este guia.
Joshua Neally
Membro desde: 09/25/17
581 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S16-G6, Eyestone Fall 2017 Membro de USF Tampa, Team S16-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S16G6
3 Membros
Autoria de 8 guias
8Comentários do guia
Where can i buy the replacement Battery? What tags should i use to find it?
Rancid 3000a - Responder Compartilhar
LC18650 Remote Control accu
djcornelissen - Responder Compartilhar
Are battery packs available for the 2017 controller?
Andrew - Responder Compartilhar
Simply reconnecting the battery fixed my issues
Charles Keisler - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 85
Ao todo: 21,582
