Ir para o conteúdo principal
Nvidia Shield Pro Android TV Motherboard Replacement
O que você precisa
  1. Nvidia Shield Pro Android TV Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Nvidia Shield Pro Android TV Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 Nvidia Shield Pro Android TV Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Use a plastic opening tool to pry open the front panel.
    Pergunte ao FixBot
    Comentar
  2. Nvidia Shield Pro Android TV Motherboard Replacement: passo 2, imagem 1 %32 Nvidia Shield Pro Android TV Motherboard Replacement: passo 2, imagem 2 %32 Nvidia Shield Pro Android TV Motherboard Replacement: passo 2, imagem 3 %32
    • Use a Torx TR6 screwdriver to remove the five 6mm screws that are securing the fan.
    • Unplug the power supply connected to the fan.
    Pergunte ao FixBot
    Comentar
  3. Nvidia Shield Pro Android TV Motherboard Replacement: passo 3, imagem 1 %32 Nvidia Shield Pro Android TV Motherboard Replacement: passo 3, imagem 2 %32
    • Unplug the two black cable bundles that are running over the motherboard.
    Pergunte ao FixBot
    Comentar
  4. Nvidia Shield Pro Android TV Motherboard Replacement: passo 4, imagem 1 %32 Nvidia Shield Pro Android TV Motherboard Replacement: passo 4, imagem 2 %32 Nvidia Shield Pro Android TV Motherboard Replacement: passo 4, imagem 3 %32
    • Use a Torx TR6 screwdriver to remove the three 5mm screws securing the motherboard.
    • Detach the black and white coaxial cables from the motherboard.
    • Lift the motherboard out of the device and disconnect the black cable bundle.
    Pergunte ao FixBot
    Comentar
Conclusão
1Comentário do guia
Please update the title of this to specify which model year Shield Pro it is for. I was looking for the 2019 model instructions and this obviously isn't that.
Thanks!
jkr4m3r - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 22
Últimos 30 dias: 108
Ao todo: 4,383
