Ir para o conteúdo principal
Nvidia Shield Pro Android TV I/O Board Replacement
O que você precisa
  1. Nvidia Shield Pro Android TV I/O Board Replacement, Bottom Cover: passo 1, imagem 1 %32 Nvidia Shield Pro Android TV I/O Board Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Flip to the back side of your Nvidia Shield Pro Android TV.
    • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
    • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
    Pergunte ao FixBot
    Comentar
  2. Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: passo 2, imagem 1 %32 Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: passo 2, imagem 2 %32 Nvidia Shield Pro Android TV I/O Board Replacement, Hard Drive: passo 2, imagem 3 %32
    • Remove the two pieces of adhesives found at the top and the bottom side of the hard drive.
    • Put the two adhesives aside. Make sure to keep them flat so that you can put them back on after.
    Pergunte ao FixBot
    Comentar
  3. Nvidia Shield Pro Android TV I/O Board Replacement: passo 3, imagem 1 %32 Nvidia Shield Pro Android TV I/O Board Replacement: passo 3, imagem 2 %32 Nvidia Shield Pro Android TV I/O Board Replacement: passo 3, imagem 3 %32
    • Detach the pack of wires by pulling it away from the socket.
    Pergunte ao FixBot
    Comentar
  4. Nvidia Shield Pro Android TV I/O Board Replacement: passo 4, imagem 1 %32 Nvidia Shield Pro Android TV I/O Board Replacement: passo 4, imagem 2 %32 Nvidia Shield Pro Android TV I/O Board Replacement: passo 4, imagem 3 %32
    • Next to the empty socket where the black wires were attached to the I/O board (refer back to Step 2), detach the plastic strap from the I/O board by pushing the strap away from the socket using your finger.
    Pergunte ao FixBot
    Comentar
  5. Nvidia Shield Pro Android TV I/O Board Replacement: passo 5, imagem 1 %32 Nvidia Shield Pro Android TV I/O Board Replacement: passo 5, imagem 2 %32
    • Remove the screw on the metal piece using a T6 Torx screwdriver and put away the metal piece after removing the screw.
    Pergunte ao FixBot
    Comentar
  6. Nvidia Shield Pro Android TV I/O Board Replacement: passo 6, imagem 1 %32
    • Gently pull the hard drive out of the device.
    Pergunte ao FixBot
    Comentar
  7. Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: passo 7, imagem 1 %32 Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: passo 7, imagem 2 %32 Nvidia Shield Pro Android TV I/O Board Replacement, I/O Board: passo 7, imagem 3 %32
    • Detach the brown side of the connector from the I/O board by pulling it upward.
    • Remove the screw from the silver plate using a T6 Torx screwdriver.
    • Put the cable aside after removing it.
    Pergunte ao FixBot
    Comentar
  8. Nvidia Shield Pro Android TV I/O Board Replacement: passo 8, imagem 1 %32 Nvidia Shield Pro Android TV I/O Board Replacement: passo 8, imagem 2 %32
    • Detach the small bundle of black wires from the I/O board by gently pulling upward.
    • Be very gentle because the wires are very fragile.
    Pergunte ao FixBot
    Comentar
  9. Nvidia Shield Pro Android TV I/O Board Replacement: passo 9, imagem 1 %32 Nvidia Shield Pro Android TV I/O Board Replacement: passo 9, imagem 2 %32
    • Remove the three T6 Torx screws from the I/O board.
    Pergunte ao FixBot
    Comentar
  10. Nvidia Shield Pro Android TV I/O Board Replacement: passo 10, imagem 1 %32 Nvidia Shield Pro Android TV I/O Board Replacement: passo 10, imagem 2 %32 Nvidia Shield Pro Android TV I/O Board Replacement: passo 10, imagem 3 %32
    • Detach the multi-colored (red/yellow/black) wire from the I/O board by pulling it away from the socket.
    Pergunte ao FixBot
    Comentar
  11. Nvidia Shield Pro Android TV I/O Board Replacement: passo 11, imagem 1 %32
    • Gently remove the I/O board by sliding it away from the exterior input/output sockets on your Nvidia Shield Pro.
    Pergunte ao FixBot
    Comentar
Conclusão
9 outras pessoas executaram este guia.
Jimmy Chen
Membro desde: 01/23/20
753 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S18-G2, White Winter 2020 Membro de Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 Membros
Autoria de 14 guias
2Comentários do guia
Where can I buy Nvidia Shield Pro Android TV I/O Board? Greentings from Brazil.
Sergio Santos - Responder Compartilhar
Aniyone managed to get a source for this part, The IO board
Yoda Mann - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 29
Últimos 30 dias: 157
Ao todo: 7,408
