Ir para o conteúdo principal
Nvidia Shield Pro Android TV Controller D-Pad Replacement
O que você precisa
  1. Nvidia Shield Pro Android TV Controller D-Pad Replacement, Bluetooth Controller D-Pad: passo 1, imagem 1 %32 Nvidia Shield Pro Android TV Controller D-Pad Replacement, Bluetooth Controller D-Pad: passo 1, imagem 2 %32 Nvidia Shield Pro Android TV Controller D-Pad Replacement, Bluetooth Controller D-Pad: passo 1, imagem 3 %32
    • Remove the six T6 Torx screws from the back of the controller.
    Pergunte ao FixBot
    Comentar
  2. Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 2, imagem 1 %32
    • Gently open the top frame of the cover with the plastic opening tool.
    Pergunte ao FixBot
    Comentar
  3. Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 3, imagem 1 %32 Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 3, imagem 2 %32
    • Gently pull the wire connector out of its socket, separating the two halves of the controller.
    Pergunte ao FixBot
    Comentar
  4. Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 4, imagem 1 %32
    • Remove the wire attached to the circular piece.
    Pergunte ao FixBot
    Comentar
  5. Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 5, imagem 1 %32 Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 5, imagem 2 %32
    • Carefully remove the two T6 Torx screws from either side of the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 6, imagem 1 %32
    • Remove the yellow plug from its socket.
    Pergunte ao FixBot
    Comentar
  7. Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 7, imagem 1 %32 Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 7, imagem 2 %32
    • Remove the two T6 Torx screws.
    Pergunte ao FixBot
    Comentar
  8. Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 8, imagem 1 %32
    • Slowly pull up the primary circuit board of the controller until the D-pad is revealed.
    • Carefully remove the board.
    Pergunte ao FixBot
    Comentar
  9. Nvidia Shield Pro Android TV Controller D-Pad Replacement: passo 9, imagem 1 %32
    • Gently remove and replace the D-Pad.
    Pergunte ao FixBot
    Comentar
Conclusão
Ben Carrasco
Membro desde: 01/23/20
347 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S18-G2, White Winter 2020 Membro de Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 50
Ao todo: 2,252
