Ir para o conteúdo principal
Nvidia Shield Display Assembly Replacement
O que você precisa
    1. Nvidia Shield Display Assembly Replacement, Remove Front Panel: passo 1, imagem 1 %32 Nvidia Shield Display Assembly Replacement, Remove Front Panel: passo 1, imagem 2 %32 Nvidia Shield Display Assembly Replacement, Remove Front Panel: passo 1, imagem 3 %32
      • Remove the seven 6.4mm T5 Torx screws from the back panel.
      • Use the spudger to separate the front and back panels.
      Pergunte ao FixBot
      Comentar
    2. Nvidia Shield Display Assembly Replacement, Remove Green Grill: passo 2, imagem 1 %32 Nvidia Shield Display Assembly Replacement, Remove Green Grill: passo 2, imagem 2 %32
      • The green grill is not screwed in so it can be pulled right out.
      Pergunte ao FixBot
      Comentar
    3. Nvidia Shield Display Assembly Replacement, Remove Battery Cables: passo 3, imagem 1 %32 Nvidia Shield Display Assembly Replacement, Remove Battery Cables: passo 3, imagem 2 %32 Nvidia Shield Display Assembly Replacement, Remove Battery Cables: passo 3, imagem 3 %32
      • Remove the six 6.5mm T5 Torx screws.
      • Disconnect the power wires.
      • Peel back the copper tape and disconnect the black and white wires.
      Pergunte ao FixBot
      Comentar
    4. Nvidia Shield Display Assembly Replacement, Remove Battery Apparatus: passo 4, imagem 1 %32
      • Pull the battery apparatus out once all cables are removed.
      Pergunte ao FixBot
      Comentar
    1. Nvidia Shield Display Assembly Replacement, Removing Fan: passo 5, imagem 1 %32 Nvidia Shield Display Assembly Replacement, Removing Fan: passo 5, imagem 2 %32 Nvidia Shield Display Assembly Replacement, Removing Fan: passo 5, imagem 3 %32
      • Cooling is important for electronics, the last thing they want is to overheat.
      • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
      • Lift the fan free after the screws and cable are removed.
      Pergunte ao FixBot
      Comentar
    1. Nvidia Shield Display Assembly Replacement, Disconnecting from logic board: passo 6, imagem 1 %32
      • On the left side from where the display is attached to the back panel there is one 3.8mm T5 Torx screw that needs to be removed.
      • Once removed, the display should be able to be detached.
      Pergunte ao FixBot
      Comentar
Conclusão
5 outras pessoas executaram este guia.
Noel Fletcher
Membro desde: 09/22/14
116 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-1, Hickman Fall 2014 Membro de USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Membros
Autoria de 72 guias
1Comentário do guia
Where can o get a replacement screen
jorge valenzuela - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 78
Ao todo: 7,354
