Ir para o conteúdo principal
Numark N4 BP Main PCB Board Replacement
O que você precisa
    1. Numark N4 BP Main PCB Board Replacement, Numark N4 Disassembly: passo 1, imagem 1 %32
      • Turn the Numark N4 over so that the bottom panel is facing upwards.
      • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Numark N4 BP Main PCB Board Replacement: passo 2, imagem 1 %32
      • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
      Pergunte ao FixBot
      Comentar
    3. Numark N4 BP Main PCB Board Replacement: passo 3, imagem 1 %32
      • Using your fingers, gently unplug the larger ribbon cable as pictured.
      Pergunte ao FixBot
      Comentar
    4. Numark N4 BP Main PCB Board Replacement: passo 4, imagem 1 %32
      • Using your fingers, gently unplug the smaller ribbon cable as pictured.
      Pergunte ao FixBot
      Comentar
    5. Numark N4 BP Main PCB Board Replacement: passo 5, imagem 1 %32
      • Using your fingers, gently unplug the yellow and red cable as pictured.
      Pergunte ao FixBot
      Comentar
    6. Numark N4 BP Main PCB Board Replacement: passo 6, imagem 1 %32
      • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
      Pergunte ao FixBot
      Comentar
    1. Numark N4 BP Main PCB Board Replacement, Numark N4 BP Main PCB Board: passo 7, imagem 1 %32
      • Loosen and remove the five 12mm screws from the circuit board using a Phillips #2 screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Numark N4 BP Main PCB Board Replacement: passo 8, imagem 1 %32
      • Carefully remove the circuit board from its housing.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Erik Charlton
Membro desde: 10/10/17
900 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S13-G11, Cagle Fall 2017 Membro de USF Tampa, Team S13-G11, Cagle Fall 2017
USFT-CAGLE-F17S13G11
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 30
Ao todo: 1,854
