Ir para o conteúdo principal
NuVision TM800A510L Battery Replacement
O que você precisa
    1. NuVision TM800A510L Battery Replacement, Battery: passo 1, imagem 1 %32 NuVision TM800A510L Battery Replacement, Battery: passo 1, imagem 2 %32
      • Use a Heat Gun to loosen the adhesive under the backing of the device.
      • Use prying tools to lift up the back of the device to get underneath.
      • I recommend concentrating on one side of the device at a time and making sure the device is 'almost too hot to touch' before you begin using the prying tools.
      • You can use either metal or plastic prying tools. Keep in mind, though, that metal ones may scratch the device.
      Pergunte ao FixBot
      Comentar
    2. NuVision TM800A510L Battery Replacement: passo 2, imagem 1 %32 NuVision TM800A510L Battery Replacement: passo 2, imagem 2 %32
      • Unlock all of the ribbons that cross or interfere with the battery.
      • Remove the unlocked ribbons if you can- this will make it easier to work with the battery later.
      Pergunte ao FixBot
      Comentar
    3. NuVision TM800A510L Battery Replacement: passo 3, imagem 1 %32
      • Use plastic prying tools to peel up the battery. Metal prying tools may puncture the battery and cause more damage. If you MUST use metal prying tools, go slow.
      • This process may take some time since the battery is held down with adhesive.
      • It is not really recommended to use the Heat Gun on the battery. However, the heat will loosen the adhesive. Therefore, if you decide to use a Heat Gun, apply the heat to the battery from underneath the device (heat the screen).
      Pergunte ao FixBot
      Comentar
    4. NuVision TM800A510L Battery Replacement: passo 4, imagem 1 %32
      • Desolder battery and wires from Motherboard HERE!
      • Once the wires are free, so is the battery. You should be able to replace the battery and its wires in full (as a package deal).
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 1,401
