Introdução
If your Nook Tablet speaker assembly component is not working properly or is broken, this guide will take you through the process of taking apart the device down to the motherboard. Then you will replace the speaker assembly with a new speaker assembly to allow for proper functioning again.
O que você precisa
Using the T5 Torx screwdriver, remove the ten T5 screws from around the edges of the silver midframe.
Lift up the foam pad at the corner of the battery to reveal the battery connector.
Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
Lift up the foam that covers the power connector and volume connector.
Disconnect the power and volume cables from their sockets on the motherboard.
Using your hands pull the square speaker assembly component off the motherboard.
Now place the new speaker assembly component back in the same square location.
As Step 12 mentions, make sure to realign the speaker assembly correctly in the square.
Uma outra pessoa concluiu este guia.
