Ir para o conteúdo principal
Nook Tablet Midframe Replacement
O que você precisa
    1. Nook Tablet Midframe Replacement, Back Cover: passo 1, imagem 1 %32
      • Flip the Nook over.
      Pergunte ao FixBot
      Comentar
    2. Nook Tablet Midframe Replacement: passo 2, imagem 1 %32 Nook Tablet Midframe Replacement: passo 2, imagem 2 %32
      • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
      • Remove the tape covering the round holes to reveal two T5 Torx screws.
      • Remove the two T5 Torx screws securing the back cover.
      Pergunte ao FixBot
      Comentar
    3. Nook Tablet Midframe Replacement: passo 3, imagem 1 %32 Nook Tablet Midframe Replacement: passo 3, imagem 2 %32
      • Insert the flat end of a spudger between the front panel and the rear assembly.
      • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
      • Use a spudger to lift the the back panel from the rest of the Nook.
      Pergunte ao FixBot
      Comentar
    4. Nook Tablet Midframe Replacement: passo 4, imagem 1 %32 Nook Tablet Midframe Replacement: passo 4, imagem 2 %32
      • Slide the spudger around the edges of the Nook to loosen the back panel.
      Pergunte ao FixBot
      Comentar
    5. Nook Tablet Midframe Replacement: passo 5, imagem 1 %32
      • Pull the back panel off the Nook.
      Pergunte ao FixBot
      Comentar
    1. Nook Tablet Midframe Replacement, Screen Bezel: passo 6, imagem 1 %32 Nook Tablet Midframe Replacement, Screen Bezel: passo 6, imagem 2 %32
      • Using the T5 Torx screwdriver, remove the ten T5 screws from around the edges of the silver midframe.
      Pergunte ao FixBot
      Comentar
    2. Nook Tablet Midframe Replacement: passo 7, imagem 1 %32 Nook Tablet Midframe Replacement: passo 7, imagem 2 %32
      • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
      Pergunte ao FixBot
      Comentar
    1. Nook Tablet Midframe Replacement, Disconnect the Battery: passo 8, imagem 1 %32 Nook Tablet Midframe Replacement, Disconnect the Battery: passo 8, imagem 2 %32
      • Lift up the foam pad at the corner of the battery to reveal the battery connector.
      • Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
      • These photos show a screwdriver, but we recommend using a nonconductive tool like a spudger to prevent a potential short.
      Pergunte ao FixBot
      Comentar
    1. Nook Tablet Midframe Replacement, Midframe: passo 9, imagem 1 %32
      • Lift up the foam that covers the power connector and volume connector.
      • Disconnect the power and volume cables from their sockets on the motherboard.
      Pergunte ao FixBot
      Comentar
    2. Nook Tablet Midframe Replacement: passo 10, imagem 1 %32 Nook Tablet Midframe Replacement: passo 10, imagem 2 %32
      • Carefully lift the silver midframe away from the motherboard and display assembly.
      • Be careful when handling the motherboard, making sure to not dislodge/shift any of its major components.
      Pergunte ao FixBot
      Comentar
Conclusão
Holly Lowe
Membro desde: 09/26/12
238 Reputação
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 19
Ao todo: 759
