Ir para o conteúdo principal
Nook Tablet Display Replacement
O que você precisa
    1. Nook Tablet Display Replacement, Back Cover: passo 1, imagem 1 %32
      • Flip the Nook over.
      Pergunte ao FixBot
      Comentar
    2. Nook Tablet Display Replacement: passo 2, imagem 1 %32 Nook Tablet Display Replacement: passo 2, imagem 2 %32
      • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
      • Remove the tape covering the round holes to reveal two T5 Torx screws.
      • Remove the two T5 Torx screws securing the back cover.
      Pergunte ao FixBot
      Comentar
    3. Nook Tablet Display Replacement: passo 3, imagem 1 %32 Nook Tablet Display Replacement: passo 3, imagem 2 %32
      • Insert the flat end of a spudger between the front panel and the rear assembly.
      • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
      • Use a spudger to lift the the back panel from the rest of the Nook.
      Pergunte ao FixBot
      Comentar
    4. Nook Tablet Display Replacement: passo 4, imagem 1 %32 Nook Tablet Display Replacement: passo 4, imagem 2 %32
      • Slide the spudger around the edges of the Nook to loosen the back panel.
      Pergunte ao FixBot
      Comentar
    5. Nook Tablet Display Replacement: passo 5, imagem 1 %32
      • Pull the back panel off the Nook.
      Pergunte ao FixBot
      Comentar
    1. Nook Tablet Display Replacement, Screen Bezel: passo 6, imagem 1 %32 Nook Tablet Display Replacement, Screen Bezel: passo 6, imagem 2 %32
      • Using the T5 Torx screwdriver, remove the ten T5 screws from around the edges of the silver midframe.
      Pergunte ao FixBot
      Comentar
    2. Nook Tablet Display Replacement: passo 7, imagem 1 %32 Nook Tablet Display Replacement: passo 7, imagem 2 %32
      • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
      Pergunte ao FixBot
      Comentar
    1. Nook Tablet Display Replacement, Disconnect the Battery: passo 8, imagem 1 %32 Nook Tablet Display Replacement, Disconnect the Battery: passo 8, imagem 2 %32
      • Lift up the foam pad at the corner of the battery to reveal the battery connector.
      • Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
      • These photos show a screwdriver, but we recommend using a nonconductive tool like a spudger to prevent a potential short.
      Pergunte ao FixBot
      Comentar
    1. Nook Tablet Display Replacement, Midframe: passo 9, imagem 1 %32
      • Lift up the foam that covers the power connector and volume connector.
      • Disconnect the power and volume cables from their sockets on the motherboard.
      Pergunte ao FixBot
      Comentar
    2. Nook Tablet Display Replacement: passo 10, imagem 1 %32 Nook Tablet Display Replacement: passo 10, imagem 2 %32
      • Carefully lift the silver midframe away from the motherboard and display assembly.
      • Be careful when handling the motherboard, making sure to not dislodge/shift any of its major components.
      Pergunte ao FixBot
      Comentar
    1. Nook Tablet Display Replacement, Display: passo 11, imagem 1 %32 Nook Tablet Display Replacement, Display: passo 11, imagem 2 %32
      • Orient the mother board as shown, so that the screen is facing downwards.
      • Grab the corner of the orange strip on the right side of the mother board as shown.
      • The orange strip is adhered to the mother board, gently lift the strip so that the adhesion is broken.
      • The strip will still be attached by the circuit connection to the mother board, proceed to the next step.
      Pergunte ao FixBot
      Comentar
    2. Nook Tablet Display Replacement: passo 12, imagem 1 %32 Nook Tablet Display Replacement: passo 12, imagem 2 %32 Nook Tablet Display Replacement: passo 12, imagem 3 %32
      • The orange strip will still be attached at this point
      • Insert the end of a flat head screw driver between the connection of the strip and mother board and pry upward.
      • Grab the strip and gently pull upward to finish the disconnection.
      Pergunte ao FixBot
      Comentar
    3. Nook Tablet Display Replacement: passo 13, imagem 1 %32 Nook Tablet Display Replacement: passo 13, imagem 2 %32
      • On the left side of the motherboard, you will see another orange strip, this one is taped down to the motherboard.
      • Remove the tape.
      Pergunte ao FixBot
      Comentar
    4. Nook Tablet Display Replacement: passo 14, imagem 1 %32 Nook Tablet Display Replacement: passo 14, imagem 2 %32 Nook Tablet Display Replacement: passo 14, imagem 3 %32
      • After the tape has been removed, the strip will still be attached to the motherboard by the hinge pictured here.
      • Slide the tip of a flat head screwdriver under the hinge and pry the hinge upward.
      • The orange strip should now be detached from the mother board.
      Pergunte ao FixBot
      Comentar
    5. Nook Tablet Display Replacement: passo 15, imagem 1 %32 Nook Tablet Display Replacement: passo 15, imagem 2 %32 Nook Tablet Display Replacement: passo 15, imagem 3 %32
      • The screen is adhered to the mother board at the screw holes marked
      • Break the adhesion by inserting the edge of a flat head screwdriver inbetween the motherboard and the pieces of the screen at the marked holes
      • Lift the screen from the display.
      Pergunte ao FixBot
      Comentar
Conclusão
12 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 1-4, Propen Fall 2012 Membro de Cal Poly, Team 1-4, Propen Fall 2012
CPSU-PROPEN-F12S1G4
4 Membros
Autoria de 14 guias
2Comentários do guia
Where can one get a replacement screen for the glow-light first model?
Hank - Responder Compartilhar
I need battery
Mister A - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 44
Ao todo: 33,083
