Ir para o conteúdo principal
Nook HD+ Charging Port Replacement
O que você precisa
  1. Nook HD+ Charging Port Replacement, Motherboard: passo 1, imagem 1 %32 Nook HD+ Charging Port Replacement, Motherboard: passo 1, imagem 2 %32 Nook HD+ Charging Port Replacement, Motherboard: passo 1, imagem 3 %32
    • Open the plastic frame by wedging the plastic iFixit opening tool under the plastic frame to remove adhesive.
    • Pop up all plastic tabs that secure the frame to the chassis.
  2. Nook HD+ Charging Port Replacement: passo 2, imagem 1 %32 Nook HD+ Charging Port Replacement: passo 2, imagem 2 %32 Nook HD+ Charging Port Replacement: passo 2, imagem 3 %32
    • Remove twenty 5.0 mm Torx T5 screws that hold the chassis to the back casing using a screwdriver.
    • Disconnect battery from motherboard.
    • Remove back casing.
  3. Nook HD+ Charging Port Replacement: passo 3, imagem 1 %32 Nook HD+ Charging Port Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Disconnect both ribbons from the motherboard by pulling up on the dark grey flaps and pulling out the ribbons.
    • Use tweezers to lift the flaps.
  4. Nook HD+ Charging Port Replacement: passo 4, imagem 1 %32
    • Disconnect the small red and black ribbon connected to the speaker from the white clip on the motherboard.
    • No tool is needed. Gently pull on the wires until the piece disconnects.
  5. Nook HD+ Charging Port Replacement: passo 5, imagem 1 %32
    • Disconnect antenna from motherboard by pulling up with slight force.
  6. Nook HD+ Charging Port Replacement: passo 6, imagem 1 %32 Nook HD+ Charging Port Replacement: passo 6, imagem 2 %32
    • Remove two 5.0 mm Torx T5 screws attached to the motherboard using a screwdriver.
    • Lift the small foam piece attached to the black strip on the motherboard and gently pull up.
  7. Nook HD+ Charging Port Replacement: passo 7, imagem 1 %32 Nook HD+ Charging Port Replacement: passo 7, imagem 2 %32
    • With the black strip lifted, carefully snap the motherboard out of the plastic pieces holding it down.
    • Remove the motherboard.
  8. Nook HD+ Charging Port Replacement, Charging Port: passo 8, imagem 1 %32 Nook HD+ Charging Port Replacement, Charging Port: passo 8, imagem 2 %32
    • Once removing the motherboard, flip it over and locate the charging port. Use a soldering iron to disconnect the charging port from the motherboard. If confused here's a reference.
    • Since the charging port is attached to the motherboard, it is simpler to replace both.
    • Soldering iron will be very hot and can both burn your hand and possibly damage the device.
    • Solder the new charging port to the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Bayleigh Fouts
Membro desde: 03/31/22
97 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 3-3, Harley Spring 2022 Membro de IUPUI, Team 3-3, Harley Spring 2022
IUPUI-HARLEY-S22S3G3
3 Membros
Autoria de 3 guias
Um comentário
Where can I obtain the replacement part?? the new charging port???
Jim Rhem - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 15
Ao todo: 871
