Ir para o conteúdo principal
Nook HD+ Antenna Replacement
O que você precisa
    1. Nook HD+ Antenna Replacement, Antenna: passo 1, imagem 1 %32
      • Pry the front frame off of the nook by wedging the plastic opening piece between the frame and the nook.
      Pergunte ao FixBot
      Comentar
    2. Nook HD+ Antenna Replacement, Remove the screws: passo 2, imagem 1 %32 Nook HD+ Antenna Replacement, Remove the screws: passo 2, imagem 2 %32
      • Remove every visible screw from the front of the nook using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
      Pergunte ao FixBot
      Comentar
    3. Nook HD+ Antenna Replacement, Remove the chassis: passo 3, imagem 1 %32 Nook HD+ Antenna Replacement, Remove the chassis: passo 3, imagem 2 %32
      • Carefully remove the center chassis from the bottom frame.
      Pergunte ao FixBot
      Comentar
    4. Nook HD+ Antenna Replacement, Dettatch battery: passo 4, imagem 1 %32 Nook HD+ Antenna Replacement, Dettatch battery: passo 4, imagem 2 %32 Nook HD+ Antenna Replacement, Dettatch battery: passo 4, imagem 3 %32
      • Detach the battery ribbon from the motherboard.
      Pergunte ao FixBot
      Comentar
    5. Nook HD+ Antenna Replacement, Flip the center chassis: passo 5, imagem 1 %32
      • Flip the center chassis so that the screen is facing down, and the hole is positioned in the bottom right corner.
      Pergunte ao FixBot
      Comentar
    6. Nook HD+ Antenna Replacement, Remove the antenna part 1: passo 6, imagem 1 %32 Nook HD+ Antenna Replacement, Remove the antenna part 1: passo 6, imagem 2 %32
      • Remove the wire from the attachment on the motherboard (this wire un-clips).
      Pergunte ao FixBot
      Comentar
    7. Nook HD+ Antenna Replacement, Remove the antenna part 2: passo 7, imagem 1 %32 Nook HD+ Antenna Replacement, Remove the antenna part 2: passo 7, imagem 2 %32
      • Apply soldering iron to the wire where it connects on the frame side. Remove wire when the solder is molten.
      Pergunte ao FixBot
      Comentar
    8. Nook HD+ Antenna Replacement, Place new antenna.: passo 8, imagem 1 %32 Nook HD+ Antenna Replacement, Place new antenna.: passo 8, imagem 2 %32
      • Replace new antenna following all the steps in reverse.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Elijah Gonsalves
Membro desde: 10/24/14
1.049 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Membro de UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 Membros
Autoria de 45 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 41
Ao todo: 1,475
