Ir para o conteúdo principal
Nook Color Speaker Replacement
O que você precisa
    1. Nook Color Speaker Replacement, Back Cover: passo 1, imagem 1 %32 Nook Color Speaker Replacement, Back Cover: passo 1, imagem 2 %32
      • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Nook Color Speaker Replacement: passo 2, imagem 1 %32 Nook Color Speaker Replacement: passo 2, imagem 2 %32
      • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
      Pergunte ao FixBot
      Comentar
    1. Nook Color Speaker Replacement, Front Cover: passo 3, imagem 1 %32
      • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Nook Color Speaker Replacement: passo 4, imagem 1 %32 Nook Color Speaker Replacement: passo 4, imagem 2 %32
      • Pry off the front panel using the plastic opening tool.
      Pergunte ao FixBot
      Comentar
    3. Nook Color Speaker Replacement: passo 5, imagem 1 %32 Nook Color Speaker Replacement: passo 5, imagem 2 %32
      • Lift up on the connectors to disconnect them using the plastic opening tool.
      Pergunte ao FixBot
      Comentar
    1. Nook Color Speaker Replacement, Speaker: passo 6, imagem 1 %32 Nook Color Speaker Replacement, Speaker: passo 6, imagem 2 %32
      • Remove the protective lining located above the speaker.
      Pergunte ao FixBot
      Comentar
    2. Nook Color Speaker Replacement: passo 7, imagem 1 %32 Nook Color Speaker Replacement: passo 7, imagem 2 %32 Nook Color Speaker Replacement: passo 7, imagem 3 %32
      • Using a plastic opening tool, push on the speaker from the front of the panel to loosen the speaker. Some force will be required. Once loose, use your index finger to push it through.
      Pergunte ao FixBot
      Comentar
    3. Nook Color Speaker Replacement: passo 8, imagem 1 %32
      • Once pressed all the way through, the speaker will be loose and free to replace.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
John Goly
Membro desde: 01/20/15
595 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 11-5, Blackwell Winter 2015 Membro de USF Tampa, Team 11-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G5
3 Membros
Autoria de 42 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 30
Ao todo: 613
