Ir para o conteúdo principal
Nook Color Display Replacement
O que você precisa
    1. Nook Color Display Replacement, Back Cover: passo 1, imagem 1 %32 Nook Color Display Replacement, Back Cover: passo 1, imagem 2 %32
      • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Nook Color Display Replacement: passo 2, imagem 1 %32 Nook Color Display Replacement: passo 2, imagem 2 %32
      • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
      Pergunte ao FixBot
      Comentar
    1. Nook Color Display Replacement, Front Cover: passo 3, imagem 1 %32
      • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Nook Color Display Replacement: passo 4, imagem 1 %32 Nook Color Display Replacement: passo 4, imagem 2 %32
      • Pry off the front panel using the plastic opening tool.
      Pergunte ao FixBot
      Comentar
    3. Nook Color Display Replacement: passo 5, imagem 1 %32 Nook Color Display Replacement: passo 5, imagem 2 %32
      • Lift up on the connectors to disconnect them using the plastic opening tool.
      Pergunte ao FixBot
      Comentar
    1. Nook Color Display Replacement, Motherboard: passo 6, imagem 1 %32 Nook Color Display Replacement, Motherboard: passo 6, imagem 2 %32 Nook Color Display Replacement, Motherboard: passo 6, imagem 3 %32
      • Gently lift and peel the orange and grey ribbon connectors to disconnect the screen and motherboard.
      Pergunte ao FixBot
      Comentar
    2. Nook Color Display Replacement: passo 7, imagem 1 %32
      • Remove the easy-to-miss T5 Torx 3.8 mm screw located in the tabbed corner of the device.
      Pergunte ao FixBot
      Comentar
    3. Nook Color Display Replacement: passo 8, imagem 1 %32 Nook Color Display Replacement: passo 8, imagem 2 %32
      • Lift the motherboard gently from the side with the larger connector ribbon.
      • Slide the white cable gently from underneath its holding place to free the motherboard completely.
      • Remove the motherboard carefully from the device.
      Pergunte ao FixBot
      Comentar
    1. Nook Color Display Replacement, Display: passo 9, imagem 1 %32 Nook Color Display Replacement, Display: passo 9, imagem 2 %32 Nook Color Display Replacement, Display: passo 9, imagem 3 %32
      • Use a plastic opening tool to gently pry the display upwards.
      • Lift the display out with your hands until the display has separated from the frame.
      Pergunte ao FixBot
      Comentar
Conclusão
8 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 11-5, Blackwell Winter 2015 Membro de USF Tampa, Team 11-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G5
3 Membros
Autoria de 42 guias
1Comentário do guia
this site doesn't sell the Nook Color display. Where did you get yours?
Suzette Garoutte - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 59
Ao todo: 4,428
