Ir para o conteúdo principal
Nook Color Battery Replacement
O que você precisa
    1. Nook Color Battery Replacement, Back Cover: passo 1, imagem 1 %32 Nook Color Battery Replacement, Back Cover: passo 1, imagem 2 %32
      • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Nook Color Battery Replacement: passo 2, imagem 1 %32 Nook Color Battery Replacement: passo 2, imagem 2 %32
      • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
      Pergunte ao FixBot
      Comentar
    1. Nook Color Battery Replacement, Front Cover: passo 3, imagem 1 %32
      • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
      Pergunte ao FixBot
      Comentar
    2. Nook Color Battery Replacement: passo 4, imagem 1 %32 Nook Color Battery Replacement: passo 4, imagem 2 %32
      • Pry off the front panel using the plastic opening tool.
      Pergunte ao FixBot
      Comentar
    3. Nook Color Battery Replacement: passo 5, imagem 1 %32 Nook Color Battery Replacement: passo 5, imagem 2 %32
      • Lift up on the connectors to disconnect them using the plastic opening tool.
      Pergunte ao FixBot
      Comentar
    1. Nook Color Battery Replacement, Battery: passo 6, imagem 1 %32 Nook Color Battery Replacement, Battery: passo 6, imagem 2 %32
      • Remove the tape which holds the wiring to the battery using a plastic opening tool.
      Pergunte ao FixBot
      Comentar
    2. Nook Color Battery Replacement: passo 7, imagem 1 %32 Nook Color Battery Replacement: passo 7, imagem 2 %32 Nook Color Battery Replacement: passo 7, imagem 3 %32
      • On the back side of the middle panel, pry the battery using the plastic opening tools.
      • Use of force is necessary since the battery is glued down.
      Pergunte ao FixBot
      Comentar
    3. Nook Color Battery Replacement: passo 8, imagem 1 %32 Nook Color Battery Replacement: passo 8, imagem 2 %32
      • Slide the connecting wire through the opening of where the battery was placed.
      Pergunte ao FixBot
      Comentar
Conclusão
6 outras pessoas executaram este guia.
John Goly
Membro desde: 01/20/15
595 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 11-5, Blackwell Winter 2015 Membro de USF Tampa, Team 11-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G5
3 Membros
Autoria de 42 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 65
Ao todo: 3,657
