Ir para o conteúdo principal
Nook BNRV300 Power Button Replacement
O que você precisa
  1. Nook BNRV300 Power Button Replacement, Power Button: passo 1, imagem 1 %32 Nook BNRV300 Power Button Replacement, Power Button: passo 1, imagem 2 %32 Nook BNRV300 Power Button Replacement, Power Button: passo 1, imagem 3 %32
    • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
    • Turn the Nook over to find the power button along the back upper edge.
    • Wedge the spudger between the top of the power button and the upper edge of the device.
    • Push the tool down to pry the button up and off.
  2. Nook BNRV300 Power Button Replacement: passo 2, imagem 1 %32
    • Using your fingers, take off the power button.
Conclusão
2Comentários do guia
My power button is not responding. Presumably I have to let the power drain because it won't shut off. Do i replace the button or the sensor beneath it?
Lydia Rice - Responder
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
dl200010 - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 31
Ao todo: 1,120
