Ir para o conteúdo principal
Nokia XL Dual Sim Battery Replacement
O que você precisa
  1. Nokia XL Dual Sim Battery Replacement, Replacing the battery: passo 1, imagem 1 %32 Nokia XL Dual Sim Battery Replacement, Replacing the battery: passo 1, imagem 2 %32 Nokia XL Dual Sim Battery Replacement, Replacing the battery: passo 1, imagem 3 %32
    • Shut off the device completely.
    • Separate the back cover from the device by gently prying the opening out at the loose locations.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar item.
    Pergunte ao FixBot
    Comentar
  2. Nokia XL Dual Sim Battery Replacement, Battery Removal: passo 2, imagem 1 %32 Nokia XL Dual Sim Battery Replacement, Battery Removal: passo 2, imagem 2 %32
    • Once the back cover is removed, the battery will be in plain sight.
    • Again, use the plastic opening tool to lift the battery. From there, you can simply remove it.
    Pergunte ao FixBot
    Comentar
  3. Nokia XL Dual Sim Battery Replacement: passo 3, imagem 1 %32
    • You will now take your new battery and insert it into its designated location. Make sure to look at the position the battery was in before you took it out so you don't damage any of it's important parts.
    • Please be aware that your new battery may need to be charged first in order for your device to power back on.
    Pergunte ao FixBot
    Comentar
Conclusão
Shadeed Bilal
Membro desde: 09/25/14
231 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-4, Brown Fall 2014 Membro de USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
3 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 48
Ao todo: 2,902
