Ir para o conteúdo principal
Nokia XL Dual SIM Disassembly
Pré-requisito somente
Este é um guia somente para pré-requisitos! Este guia faz parte de outro procedimento e não deve ser usado sozinho.
O que você precisa
  1. Nokia XL Dual SIM Disassembly, Back Cover Removal: passo 1, imagem 1 %32
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
    Pergunte ao FixBot
    Comentar
  2. Nokia XL Dual SIM Disassembly, Battery Removal: passo 2, imagem 1 %32 Nokia XL Dual SIM Disassembly, Battery Removal: passo 2, imagem 2 %32
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
    Pergunte ao FixBot
    Comentar
  3. Nokia XL Dual SIM Disassembly, Screen Separation part 1: passo 3, imagem 1 %32 Nokia XL Dual SIM Disassembly, Screen Separation part 1: passo 3, imagem 2 %32
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
    Pergunte ao FixBot
    Comentar
  4. Nokia XL Dual SIM Disassembly, Screen Separation part 2: passo 4, imagem 1 %32 Nokia XL Dual SIM Disassembly, Screen Separation part 2: passo 4, imagem 2 %32 Nokia XL Dual SIM Disassembly, Screen Separation part 2: passo 4, imagem 3 %32
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
    Pergunte ao FixBot
    Comentar
  5. Nokia XL Dual SIM Disassembly, System components: passo 5, imagem 1 %32
    • Once the device is open, take note of all the components.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Shadeed Bilal
Membro desde: 09/25/14
231 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-4, Brown Fall 2014 Membro de USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
3 Membros
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 24
Ao todo: 455
