Ir para o conteúdo principal
Nokia X Display Assembly Replacement
O que você precisa
  1. Nokia X Display Assembly Replacement, Battery: passo 1, imagem 1 %32
    • The first step is to remove the back cover off of the phone. To do this, place both your thumbs on the two top corners of the device and simply pop it off.
    Pergunte ao FixBot
    Comentar
  2. Nokia X Display Assembly Replacement: passo 2, imagem 1 %32
    • To remove the battery, simply use your finger to pry the battery out of its slot.
    Pergunte ao FixBot
    Comentar
  3. Nokia X Display Assembly Replacement: passo 3, imagem 1 %32
    • Inserting a new battery is as simple as lining up the gold connectors and sliding the battery in text-side down.
    Pergunte ao FixBot
    Comentar
  4. Nokia X Display Assembly Replacement, Display Assembly: passo 4, imagem 1 %32 Nokia X Display Assembly Replacement, Display Assembly: passo 4, imagem 2 %32
    • Remove the four 5.33mm T5 Torx screws which are located in the corners of the phone.
    • Remove the seven 4.00mm T5 Torx screws that line the phone between the corners.
    Pergunte ao FixBot
    Comentar
  5. Nokia X Display Assembly Replacement: passo 5, imagem 1 %32 Nokia X Display Assembly Replacement: passo 5, imagem 2 %32
    • To remove the screen from the motherboard, you will need to apply some force until you feel it snap off. If the connectors unhook themselves, don't worry.
    Pergunte ao FixBot
    Comentar
  6. Nokia X Display Assembly Replacement: passo 6, imagem 1 %32
    • If the connectors are still attached, simply unhook them by lifting the top of the connector with your finger.
    Pergunte ao FixBot
    Comentar
Conclusão
29 outras pessoas executaram este guia.
Avery Dorsey
Membro desde: 01/21/15
1.894 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 6-1, Brown Winter 2015 Membro de USF Tampa, Team 6-1, Brown Winter 2015
USFT-BROWN-W15S6G1
3 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 6,348
