Ir para o conteúdo principal
Nokia N70 Display Replacement
O que você precisa
  1. Nokia N70 Display Replacement, Battery: passo 1, imagem 1 %32
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
    Pergunte ao FixBot
    Comentar
  2. Nokia N70 Display Replacement: passo 2, imagem 1 %32
    • Remove the battery cover by lifting it away from the phone.
    Pergunte ao FixBot
    Comentar
  3. Nokia N70 Display Replacement: passo 3, imagem 1 %32
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
    Pergunte ao FixBot
    Comentar
  4. Nokia N70 Display Replacement: passo 4, imagem 1 %32
    • Remove the battery from the phone.
    Pergunte ao FixBot
    Comentar
  5. Nokia N70 Display Replacement, Keypad: passo 5, imagem 1 %32 Nokia N70 Display Replacement, Keypad: passo 5, imagem 2 %32 Nokia N70 Display Replacement, Keypad: passo 5, imagem 3 %32
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
    Pergunte ao FixBot
    Comentar
  6. Nokia N70 Display Replacement: passo 6, imagem 1 %32 Nokia N70 Display Replacement: passo 6, imagem 2 %32 Nokia N70 Display Replacement: passo 6, imagem 3 %32
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
    Pergunte ao FixBot
    Comentar
  7. Nokia N70 Display Replacement, Display: passo 7, imagem 1 %32
    • Using a torx T6 screwdriver remove the six 15 mm torx screws.
    Pergunte ao FixBot
    Comentar
  8. Nokia N70 Display Replacement: passo 8, imagem 1 %32 Nokia N70 Display Replacement: passo 8, imagem 2 %32
    • Separate the front panel of the phone by pulling the bottom of the panel at a 45 degree angle.
    Pergunte ao FixBot
    Comentar
  9. Nokia N70 Display Replacement: passo 9, imagem 1 %32 Nokia N70 Display Replacement: passo 9, imagem 2 %32
    • Lift the bottom of the display circuit board up and locate the ribbon connection located where the two circuit boards intersect.
    • Remove the ribbon connection that connects the two circuit boards.
    Pergunte ao FixBot
    Comentar
  10. Nokia N70 Display Replacement: passo 10, imagem 1 %32 Nokia N70 Display Replacement: passo 10, imagem 2 %32 Nokia N70 Display Replacement: passo 10, imagem 3 %32
    • While pulling back each of the clamps marked in the image, lift out each side of the screen independently.
    • Be careful when using the plastic prying tool to not scratch the display.
    Pergunte ao FixBot
    Comentar
Conclusão
8 outras pessoas executaram este guia.
Justin
Membro desde: 10/12/11
1.026 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 6-2, Regan Fall 2011 Membro de Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 58
Ao todo: 9,548
