Ir para o conteúdo principal
Nokia N70 Back Camera Replacement
O que você precisa
  1. Nokia N70 Back Camera Replacement, Battery: passo 1, imagem 1 %32
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
    Pergunte ao FixBot
    Comentar
  2. Nokia N70 Back Camera Replacement: passo 2, imagem 1 %32
    • Remove the battery cover by lifting it away from the phone.
    Pergunte ao FixBot
    Comentar
  3. Nokia N70 Back Camera Replacement: passo 3, imagem 1 %32
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
    Pergunte ao FixBot
    Comentar
  4. Nokia N70 Back Camera Replacement: passo 4, imagem 1 %32
    • Remove the battery from the phone.
    Pergunte ao FixBot
    Comentar
  5. Nokia N70 Back Camera Replacement, Keypad: passo 5, imagem 1 %32 Nokia N70 Back Camera Replacement, Keypad: passo 5, imagem 2 %32 Nokia N70 Back Camera Replacement, Keypad: passo 5, imagem 3 %32
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
    Pergunte ao FixBot
    Comentar
  6. Nokia N70 Back Camera Replacement: passo 6, imagem 1 %32 Nokia N70 Back Camera Replacement: passo 6, imagem 2 %32 Nokia N70 Back Camera Replacement: passo 6, imagem 3 %32
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
    Pergunte ao FixBot
    Comentar
  7. Nokia N70 Back Camera Replacement, Back Camera: passo 7, imagem 1 %32 Nokia N70 Back Camera Replacement, Back Camera: passo 7, imagem 2 %32
    • Using T6 Torx screwdriver remove the six 15 mm torx screws.
    Pergunte ao FixBot
    Comentar
  8. Nokia N70 Back Camera Replacement: passo 8, imagem 1 %32 Nokia N70 Back Camera Replacement: passo 8, imagem 2 %32 Nokia N70 Back Camera Replacement: passo 8, imagem 3 %32
    • Separate the front panel from the back by lifting the bottom of the front panel at a 45 degree angle.
    • Remove the front panel by lifting the panel away from the phone at a 45 degree angle.
    Pergunte ao FixBot
    Comentar
  9. Nokia N70 Back Camera Replacement: passo 9, imagem 1 %32 Nokia N70 Back Camera Replacement: passo 9, imagem 2 %32 Nokia N70 Back Camera Replacement: passo 9, imagem 3 %32
    • Locate the rear circuit board by flipping over the front panel.
    • Locate the rear camera and by using the plastic opening tool, gently lift the camera out of the slot.
    • Caution: Be careful when prying camera out of the slot for the connections are fragile.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Justin
Membro desde: 10/12/11
1.026 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 6-2, Regan Fall 2011 Membro de Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 Membros
Autoria de 11 guias
1Comentário do guia
mon nokia n70 est mal camera alors quest -ce qu*on va faire
sidiahmed ahmed - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 60
Ao todo: 9,425
