Ir para o conteúdo principal
Nokia Lumia 930 Vibration Module Replacement
O que você precisa
  1. Nokia Lumia 930 Vibration Module Replacement, Battery: passo 1, imagem 1 %32
    • Pull the SIM card holder out of the top of the phone using your fingernail.
    Pergunte ao FixBot
    Comentar
  2. Nokia Lumia 930 Vibration Module Replacement: passo 2, imagem 1 %32 Nokia Lumia 930 Vibration Module Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Place tweezers or an opening tool in the SIM card slot and push upwards until the back panel pops out.
    Pergunte ao FixBot
    Comentar
  3. Nokia Lumia 930 Vibration Module Replacement: passo 3, imagem 1 %32 Nokia Lumia 930 Vibration Module Replacement: passo 3, imagem 2 %32
    • Wedge a plastic opening tool between the two panels. Slide it along each side of the phone to completely remove the back panel.
    Pergunte ao FixBot
    Comentar
  4. Nokia Lumia 930 Vibration Module Replacement: passo 4, imagem 1 %32
    • Remove the 4mm Torx #4 screw that's securing the battery connector.
    Pergunte ao FixBot
    Comentar
  5. Nokia Lumia 930 Vibration Module Replacement: passo 5, imagem 1 %32
    • Use tweezers to remove the battery connector strap.
    Pergunte ao FixBot
    Comentar
  6. Nokia Lumia 930 Vibration Module Replacement: passo 6, imagem 1 %32 Nokia Lumia 930 Vibration Module Replacement: passo 6, imagem 2 %32
    • Remove all ten 4mm Torx #4 screws that secure the battery cover to the frame of the phone.
    Pergunte ao FixBot
    Comentar
  7. Nokia Lumia 930 Vibration Module Replacement: passo 7, imagem 1 %32 Nokia Lumia 930 Vibration Module Replacement: passo 7, imagem 2 %32 Nokia Lumia 930 Vibration Module Replacement: passo 7, imagem 3 %32
    • Use the flat end of a spudger to pry the battery cover from the phone's frame.
    Pergunte ao FixBot
    Comentar
  8. Nokia Lumia 930 Vibration Module Replacement: passo 8, imagem 1 %32
    • Pull up on the heat spreader.
    • Be careful not to tear it!
    Pergunte ao FixBot
    Comentar
  9. Nokia Lumia 930 Vibration Module Replacement: passo 9, imagem 1 %32
    • Use the flat end of the spudger to lift up the battery.
    • The battery is glued in place. Pry up carefully, not to damage it.
    • Two flex cables are directly underneath the battery.
    Pergunte ao FixBot
    Comentar
  10. Nokia Lumia 930 Vibration Module Replacement: passo 10, imagem 1 %32
    • Remove the battery from the phone.
    Pergunte ao FixBot
    Comentar
  11. Nokia Lumia 930 Vibration Module Replacement, Motherboard: passo 11, imagem 1 %32 Nokia Lumia 930 Vibration Module Replacement, Motherboard: passo 11, imagem 2 %32
    • Use the flat end of a spudger to disconnect the camera connectors.
    • Pull the camera up and out to remove it from the phone.
    Pergunte ao FixBot
    Comentar
  12. Nokia Lumia 930 Vibration Module Replacement: passo 12, imagem 1 %32
    • Use the flat end of a spudger to disconnect the six ribbon cables from the motherboard.
    Pergunte ao FixBot
    Comentar
  13. Nokia Lumia 930 Vibration Module Replacement: passo 13, imagem 1 %32 Nokia Lumia 930 Vibration Module Replacement: passo 13, imagem 2 %32 Nokia Lumia 930 Vibration Module Replacement: passo 13, imagem 3 %32
    • Use the flat end of a spudger to pry up the orange flex cable underneath the battery.
    • Remove the orange flex cable from the phone.
    Pergunte ao FixBot
    Comentar
  14. Nokia Lumia 930 Vibration Module Replacement: passo 14, imagem 1 %32
    • Repeat the previous step for the black jumper flex cable under the battery.
    Pergunte ao FixBot
    Comentar
  15. Nokia Lumia 930 Vibration Module Replacement: passo 15, imagem 1 %32 Nokia Lumia 930 Vibration Module Replacement: passo 15, imagem 2 %32
    • Use the flat end of a spudger to disconnect both ends of the antenna cable from the motherboard.
    • Remove the antenna.
    Pergunte ao FixBot
    Comentar
  16. Nokia Lumia 930 Vibration Module Replacement: passo 16, imagem 1 %32
    • Use tweezers to grab the adhesive that is under the LTE flex cable and pull it outwards and towards the bottom end of the phone.
    • Apply new adhesive when reassembling the phone.
    Pergunte ao FixBot
    Comentar
  17. Nokia Lumia 930 Vibration Module Replacement: passo 17, imagem 1 %32 Nokia Lumia 930 Vibration Module Replacement: passo 17, imagem 2 %32 Nokia Lumia 930 Vibration Module Replacement: passo 17, imagem 3 %32
    • Use a spudger to pry up the bottom end of the motherboard, then pull it out.
    Pergunte ao FixBot
    Comentar
  18. Nokia Lumia 930 Vibration Module Replacement, Daughterboard: passo 18, imagem 1 %32 Nokia Lumia 930 Vibration Module Replacement, Daughterboard: passo 18, imagem 2 %32
    • Use the pointed end of the spudger to pry up the daughterboard.
    • Use tweezers to lift the daughterboard out of the phone.
    Pergunte ao FixBot
    Comentar
  19. Nokia Lumia 930 Vibration Module Replacement, Vibration Module: passo 19, imagem 1 %32 Nokia Lumia 930 Vibration Module Replacement, Vibration Module: passo 19, imagem 2 %32
    • Use a pair of tweezers to remove the vibration boot that covers the module.
    Pergunte ao FixBot
    Comentar
  20. Nokia Lumia 930 Vibration Module Replacement: passo 20, imagem 1 %32
    • Use the flat end of the spudger to lift the module off of the adhesive.
    • Be delicate so that you don't break off the rotating piece of the module.
    Pergunte ao FixBot
    Comentar
  21. Nokia Lumia 930 Vibration Module Replacement: passo 21, imagem 1 %32 Nokia Lumia 930 Vibration Module Replacement: passo 21, imagem 2 %32
    • Use tweezers to continually lift the module and flex up off of the adhesive.
    • Pull up until the vibration module is completely removed.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 34
Ao todo: 594
