Introdução
How to disassemble the phone and replace the display assembly - Touch screen glass, LCD Display and middle frame.
O que você precisa
Vídeo de Apresentação
Remove the battery and any SIM and memory cards.
Remove the black sticker at the bottom side of the phone.
Use a screwdriver Torx T4 and remove the 7x screws.
There are two other smaller screws with the same head size – remove them as well.
You need a decent quality T4 screwdriver here - the rubbish on that cm free with the screen assembly I bought failed completely to grip or loosen the screws. With one from a decent set (ForgeSteel from ScrewFix) they came out easily. A fridge magnet is useful to keep the screws on.
Put the earpiece on the new display assembly and start with reassembling.
17 outras pessoas executaram este guia.
2 comentários
Where do i get the part replacements from to replace the screen and what not?
Großes Lob an Nokia, das ist noch ein super zu öffnendes Smartphone gewesen! Touchdisplay tauschen war einfach.
