Ir para o conteúdo principal
Nokia E71x Battery Replacement
  1. Nokia E71x Battery Replacement, Battery: passo 1, imagem 1 %32 Nokia E71x Battery Replacement, Battery: passo 1, imagem 2 %32
    • Use your fingers to lift the battery out of the phone.
    Pergunte ao FixBot
    Comentar
Conclusão
Once the new battery is securely installed, you are ready to put your phone back together. Simply reverse the steps you followed to disassemble your Nokia E71x. Make sure all components fit snugly back into their places. Power on your device to ensure everything is working correctly. Congratulations on successfully replacing your battery! Your Nokia E71x should now be ready.
Uma outra pessoa concluiu este guia.
Will Goldby
Membro desde: 08/29/11
187 Reputação
Autoria de 4 guias
Equipe
Cuesta, Team 1-1, Zipperian Fall 2011 Membro de Cuesta, Team 1-1, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G1
3 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 35
Ao todo: 1,499
