Ir para o conteúdo principal
Nokia 6560 Keyboard Replacement
O que você precisa
  1. Nokia 6560 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Nokia 6560 Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Remove the back cover of your cell phone by pushing the small slider with your fingernail towards the top of the phone.
    • Lift off your cell phone's back cover.
    Pergunte ao FixBot
    Comentar
  2. Nokia 6560 Keyboard Replacement: passo 2, imagem 1 %32 Nokia 6560 Keyboard Replacement: passo 2, imagem 2 %32
    • Use your index finger to first push down and then lift up the battery as shown.
    • Remove the battery from your cell phone.
    Pergunte ao FixBot
    Comentar
  3. Nokia 6560 Keyboard Replacement, Keypad: passo 3, imagem 1 %32 Nokia 6560 Keyboard Replacement, Keypad: passo 3, imagem 2 %32
    • Open the front cover of your cell phone with the plastic opening tool or finger nail.
    • Lift the cover upwards, starting from the bottom below the keypad.
    Pergunte ao FixBot
    Comentar
  4. Nokia 6560 Keyboard Replacement: passo 4, imagem 1 %32 Nokia 6560 Keyboard Replacement: passo 4, imagem 2 %32
    • Lift the keypad off of the keyboard as it is not attached to the phone anymore.
    • If you want to clean your keyboard do not use chemical cleaners or too much water, instead, use a damp cloth.
    • It may be tricky to get the keypad in the right position while closing the front cover for the reassembly. Ensure they are aligned properly before closing the front cover!
    Pergunte ao FixBot
    Comentar
  5. Nokia 6560 Keyboard Replacement, Keyboard: passo 5, imagem 1 %32
    • Unscrew the six T6 torx screws which attach the frame to the cell phone case.
    • Be careful not to scratch your display with the screw driver.
    Pergunte ao FixBot
    Comentar
  6. Nokia 6560 Keyboard Replacement: passo 6, imagem 1 %32
    • Lift the frame off of your cell phone.
    Pergunte ao FixBot
    Comentar
  7. Nokia 6560 Keyboard Replacement: passo 7, imagem 1 %32
    • Lift the keyboard out of the plastic frame.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Tim Bergmann
Membro desde: 01/18/10
35 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 3-17, Maness Winter 2010 Membro de Cal Poly, Team 3-17, Maness Winter 2010
CPSU-MANESS-W10S3G17
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 28
Ao todo: 1,791
