Ir para o conteúdo principal
Nokia 6350-1b Battery Replacement
O que você precisa
  1. Nokia 6350-1b Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove the back cover of the phone by sliding it downwards.
    • This will be a thin panel that has three stripes to provide better grip.
    Pergunte ao FixBot
    Comentar
  2. Nokia 6350-1b Battery Replacement: passo 2, imagem 1 %32
    • Caution: When you slide the panel downwards, it will immediately come loose.
    • Remove the BP-6MT battery. There should be an indent showing where you will lift.
    Pergunte ao FixBot
    Comentar
  3. Nokia 6350-1b Battery Replacement: passo 3, imagem 1 %32
    • Once you have removed the old battery, you can begin to install the new battery.
    • Line up the gold indentations in the upper left corner of the battery with the three gold indentations in the upper left hand corner of the empty battery space.
    Pergunte ao FixBot
    Comentar
  4. Nokia 6350-1b Battery Replacement: passo 4, imagem 1 %32
    • Ensure that when you have lined up the battery, you are able to seamlessly insert into phone.
    • Note: If it does not slide seamlessly, it is not being inserted correctly
    Pergunte ao FixBot
    Comentar
  5. Nokia 6350-1b Battery Replacement: passo 5, imagem 1 %32
    • After the battery has clicked in, you need to reinstall the back panel of the phone.
    • Line the back panel up with the phone.
    Pergunte ao FixBot
    Comentar
  6. Nokia 6350-1b Battery Replacement: passo 6, imagem 1 %32
    • Line up the back panel starting from the bottom.
    • Once lined and pressed down, slide upward. You should be able to feel and hear it click back into place.
    Pergunte ao FixBot
    Comentar
Conclusão
Anna
Membro desde: 04/13/12
25 Reputação
Autoria de 2 guias
Equipe
SUNY Cortland, Team 1-2, Getto Spring 2012 Membro de SUNY Cortland, Team 1-2, Getto Spring 2012
SUNYCORT-GETTO-S12S1G2
2 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 26
Ao todo: 1,714
