Ir para o conteúdo principal
Nokia 6086 Screen Replacement
O que você precisa
  1. Nokia 6086 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
    Pergunte ao FixBot
    Comentar
  2. Nokia 6086 Screen Replacement: passo 2, imagem 1 %32 Nokia 6086 Screen Replacement: passo 2, imagem 2 %32 Nokia 6086 Screen Replacement: passo 2, imagem 3 %32
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    Pergunte ao FixBot
    Comentar
  3. Nokia 6086 Screen Replacement: passo 3, imagem 1 %32 Nokia 6086 Screen Replacement: passo 3, imagem 2 %32 Nokia 6086 Screen Replacement: passo 3, imagem 3 %32
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
    Pergunte ao FixBot
    Comentar
  4. Nokia 6086 Screen Replacement, Top Front Cover: passo 4, imagem 1 %32
    • Close the phone.
    • Face the front cover forward.
    Pergunte ao FixBot
    Comentar
  5. Nokia 6086 Screen Replacement: passo 5, imagem 1 %32 Nokia 6086 Screen Replacement: passo 5, imagem 2 %32
    • Locate the 4.5 mm notch at the top of the phone.
    • Place the iPod opening tool into the opening.
    • Slightly prop up the top section by lifting the tool.
    Pergunte ao FixBot
    Comentar
  6. Nokia 6086 Screen Replacement: passo 6, imagem 1 %32 Nokia 6086 Screen Replacement: passo 6, imagem 2 %32 Nokia 6086 Screen Replacement: passo 6, imagem 3 %32
    • Wedge the iPod opening tool between the top cover and the phone.
    • Gently lift the top cover away from the phone using the iPod opening tool.
    • This unlatches each hook that connects the top cover to the phone.
    • Repeat for both the left and the right sides of the phone.
    • Place the top cover aside once the top cover is completely disconnected from the phone.
    Pergunte ao FixBot
    Comentar
  7. Nokia 6086 Screen Replacement, Screen: passo 7, imagem 1 %32 Nokia 6086 Screen Replacement, Screen: passo 7, imagem 2 %32 Nokia 6086 Screen Replacement, Screen: passo 7, imagem 3 %32
    • Locate the four screws on the phone.
    • The top right screw is located under the black connector piece.
    • To remove the connector piece gently lift it off of its connector.
    • Take the T6 driver and remove the screws.
    Pergunte ao FixBot
    Comentar
  8. Nokia 6086 Screen Replacement: passo 8, imagem 1 %32
    • Carefully lift up the motherboard.
    Pergunte ao FixBot
    Comentar
  9. Nokia 6086 Screen Replacement: passo 9, imagem 1 %32 Nokia 6086 Screen Replacement: passo 9, imagem 2 %32
    • Find the orange slip on the motherboard.
    • Peel back the orange slip to expose the screen.
    Pergunte ao FixBot
    Comentar
  10. Nokia 6086 Screen Replacement: passo 10, imagem 1 %32 Nokia 6086 Screen Replacement: passo 10, imagem 2 %32 Nokia 6086 Screen Replacement: passo 10, imagem 3 %32
    • Place the ipod opening tool under the screen.
    • Remove the damaged screen with the ipod opening tool.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Caitlin Rahm
Membro desde: 04/15/10
78 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 26-30, Regan Spring 2010 Membro de Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 Membros
Autoria de 18 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 48
Ao todo: 3,830
